Oct 13, 2020, 11:34 AM
Guizzo 17's Avatar
Question
I need advice for this motor
Hi gents! I got the motor in the picture from a friend who rewound it with a 9 turn, 30 gauge wire, Y.
The size of the motor is 1303 and I wonder what could be the maximum current I may feed it.
Am I right if I guess that a 3x2 prop could be too much with a 2s Lipo?
Oct 21, 2020, 06:43 AM
Jack
jackerbes's Avatar
Most brushless motors will handle about 3 Watts of power for each gram of their overall weight. And as the power increases from that the motor will get warmer and can eventually damage itself.
Watts = Volts x Amps - if that is a 6 gram motor and you are using a 2S battery at 8 Volts you don't want to use it continuously at much over 48 Watts (6g x 8V = 48W). That was my mistake, you don't want to use it continuously at much over 18 Watts (6 grams x 3 = 18). And on a 2S battery that would be with the motor drawing about 2.25A at 8V (2.25A x 8V = 18 Watts)
To test it run the motor for one minute or so at half throttle and then feel the motor base with your fingers, if it is so hot you cannot keep your fingers on it, you are drawing too much current. And the solution for that would be to use a smaller propeller or reduce the throttle some.
Jack
Oct 21, 2020, 02:22 PM
Greediest Suer
Ron H's Avatar
Shouldn't that be 6 grams x 3 watts ?
Oct 21, 2020, 05:56 PM
Jack
jackerbes's Avatar
Yep, that was my stupid mistake! I have corrected it and thanks for pointing that out.
Jack
Oct 21, 2020, 07:31 PM
Greediest Suer
Ron H's Avatar
No problem, I figured it was a simple mistake. But someone might see it and apply it at any time if not corrected. No need to have bad information tied to your good name here.
Oct 22, 2020, 04:43 PM
Guizzo 17's Avatar
Thanks Ron. But what puzzles me is that the wire needs to carry 2.25A for 18watts which, IMO, is a bit too much for a 30 gauge wire, or am I wrong?
Oct 22, 2020, 05:57 PM
Jack
jackerbes's Avatar
There are three sets of windings there if I understand the motor right, so the 2.25A would be the total for the three. Wouldn't that make each set of windings be drawing about 1/3rd of the total.
If the poster had identified the make and model of the motor we could give better answers I think...
Here is a similar motor and it says it is wound with 27 AWG wire if I understand their advertising:
https://fpvcycle.com/products/fpvcyc...2mm-prop-shaft
Jack
Oct 23, 2020, 12:52 AM
Skylar's Avatar
AFAIK, two of the three phases fire at the same time, while the third measures back EMF to synchronize the speed. So each wire would carry 1.25A - which is perfectly fine for 30AWG wires. If you're concerned, cut the wires shorter, but I wouldn't worry about it.
Oct 23, 2020, 12:23 PM
Guizzo 17's Avatar
Jack, the motor was rewound with a single 9 turn, 30 gauge wire with star connection.
It was sold by Hobby King but, unfortunately, it is not more available.
Originally it was wound with a single 12 turn, 32 gauge wire, which fused under a 3x2 prop load, fed by a two cell Lipo.
Skylar, what you say may be right for a Delta connection, however for a Star is sure that one phase carry all the current.
Anyway I found what I was looking for in the net.
Max current for a 30 AWG wire is 0.52Amp
Thank you both for your interest.
Oct 24, 2020, 12:16 AM
Skylar's Avatar
I'd be interested to know the source of that information. Can you provide a link?
It's actually the other way around. As shown in the diagrams below:
In Delta, phase A-B consists of coil 2 placed in parallel with coils 1 & 3 in series.
In Star, phase A-B consists of only coils 1 & 2 in series without coil 3 being used.
But let's not debate the current carrying capacity of Delta vs Star. What I meant was that the ESC fires two wires together while the other
wire senses back EMF. That has been my understanding... not that I'm an expert on the subject of ESC's. Perhaps Ron can confirm if it's correct or not.
"Don't believe everything you see on the Internet" -- Winston Churchill
Oct 24, 2020, 05:26 PM
Guizzo 17's Avatar
Skylar, the net gives you different answers, I choose the one that looks sensible to me! The rationale is that I do not need all the Watts this motor may adsorb and I prefer to stay on the safe side! Links are here
and here
For what concerns Star or Delta, I see that we misunderstood each other!
Cheers!
Oct 25, 2020, 04:55 AM
Skylar's Avatar
and here
Thanks Guizzo 17. Both those links point to www.buildmyowncabin.com where "ampacity" of very long wires are discussed. 7000ft is mentioned in the video. I'm sure you'll appreciate that in brushless motors, and especially your small motor, we are dealing with much shorter distances. So I tend to not limit myself by the rules for domestic wiring. IOW, we are not wiring houses, just small motors.
Here is the table in the video that you linked.
Let's take an example. The motor pictured below was rewound by Dr Ralph Okon (powercroco) and it draws several hundred amps! I'm not sure, but I think the wire diameter is in the region of 1.6mm dia. According to the ampacity table, the safe current for 14 gauge (1.6mm) wire is 15A max. So this winding exceeds the "ampacity" rule for house wiring by a very great margin.
Ok, I agree, that is an extreme example and the motor is not run for very long. A better example would be motors using 80A and 100A ESC's. And if you look at their conductor sizes, it would be obvious that those motors also exceed the ampacity rule by a large amount.
Therefore, the "Max current for a 30 AWG wire" is quite a bit higher than 0.52Amp when we're talking motors.
Nov 20, 2020, 12:05 AM
Sokol
JureZ's Avatar
I did something similar with a small 10g brushless motor:
https://hobbyking.com/en_us/18-11-20...___store=en_us
custom rewound , Y , 36 Turns per tooth , AWG 33 wire , Kv= 635 ,
Battery 2S 300 mAh 30C,
APC 7*3.8 SF Propeller ,
Static test current draw at full throttle : 2.2A @ 8V , ~17.6W into the ESC.
page in my blog:
https://www.rcgroups.com/forums/show...ll-13-diameter
Latest blog entry: Brooklyn Dodger
Discussion Fox News unknowingly quotes from Monty Python skit Sonny McGhee Life, The Universe, and Politics 15 Jun 17, 2020 12:02 PM
Help! Unknow Usb device kaio ken FrSky 8 Apr 20, 2020 08:56 AM
Discussion Unknow esc use Hollywood_FPV Multirotor Drone Electronics 1 Nov 02, 2018 07:19 PM
Help! Beautifull but unknow Japan F3A Odisseo Fuel Plane Talk 1 Nov 23, 2015 08:09 PM
Discussion Motor watts unknowe Fly Boy3 Power Systems 9 Nov 24, 2014 01:59 PM
