Lumenier QAV-CINE Freybott Edition (2.5")
The Lumenier QAV-CINE Freybott Edition is a versatile micro sized (2.5" props) FPV quadcopter designed to be small and agile with full propeller protection all while still carrying a "naked" GoPro camera.
Designed for both HD and Analog Systems
Lumenier has teamed up with world-renowned FPV pilot Phil Freybott to bring you the ultimate micro cinematography rig. Phil is the founder of Cinequads, which is a FPV based cinematography company creating high quality cinematic content with the use of FPV drones. Phil has many years of experience shooting professionally with FPV drones on TV commercial sets, movies, and automotive brands like Porsche and Mercedes to name a few. Through his professional experience and optimized work flow, and combined with Lumenier's high quality design and manufacturing, they bring you the ultimate 2.5" FPV drone.
The QAV-CINE frame was designed from the ground up to be very versatile and allow many different configurations with the same design. This one airframe design fits 20x20 stacks, 25.5x25.5 toothpick AIO boards, Caddx Vista digital HD system, mounting points for antenna, camera, receiver transmitter and more. Now you can fly in full digital HD in an incredibly small package!
This airframe design supports both standard motor mounting and pusher configuration. In the pusher configuration it was found to have 15-20% more flight time and even better throttle response. Many "pusher" style frames struggle to easily take off from the ground since their props are often resting on the surface, but with the QAV-CINE it's no problem since the entire prop is surrounded by carbon fiber. This gives you plenty of clearance to take-off and land without any issue.
With an all up weight of just 53g this airframe is top in class. It has the perfect balance of durability and protection that you need, without any extra dead weight that you don't. The body is made up of ultra-strong 3K carbon fiber paired with beautiful multi-colored chromed aluminum standoffs. Combined with custom light-weight quick-swap battery straps and M2 hardware, this kit is the perfect 2.5" setup.
Want to add 4k buttery smooth video recording to your QAV-CINE? No problem the frame is designed to carry a "naked" style GoPro camera with a dedicated camera mounting bard on top. This allows a variety of cases and 3-D prints to securely hold the GoPro camera in place making sure you get the perfect shot!
The QAV-CINE Freybott Edition gives you the option to fly with only the Carbon Fiber frame, or add extra protection with the snap on foam bumpers. Flying close to people or object that you need a little more security? No problem! Simply pop on the foam pads in seconds and you're good to go. When you're done you can take them back off and flying again with just the carbon guards. Easy!
Check out the Lumenier QAV-Cine Freybott Edition Here
Oct 27, 2020, 03:36 AM
i fly it for some time now, its just awesome. my favorite 2,5 inch
Whoops! Eachine Viswhoop 2.5 Inch 130mm 4S Cine Whoop with DJI FPV - 199$! AWESOME!!! Originalas Micro Multirotor Drones 11 Aug 26, 2020 04:41 PM
New Product Lumenier QAV-R 2 Slam 220/260/300mm 5/6/7 Inch Carbon Fiber FPV Racing Frame Kit Merch Banggood.com 0 Jun 18, 2019 05:27 AM
New Product Lumenier QAV-R 2 220/260/300mm 5/6/7 Inch 3K Carbon Fiber 4.5mm Arm FPV Racing Frame Merch Banggood.com 0 Jun 04, 2019 05:38 AM
New Product QAV-R FPV Racing Quadcopter (4", 5", 6") by Lumenier (formerly RaceBlade) GetFPV Mini Multirotor Drones 607 May 15, 2019 10:47 AM
