Oct 11, 2020, 01:31 AM
Question
FS-i6X mapping switch C+D to channel 5 for flight modes
The Ardupilot documentation states that if you want to support 6 flight modes for a copter, then the transmitter will need to emit PWM widths of around 1165, 1295, 1425, 1555, 1685, and 1815 milliseconds. Typically this is achieved by configuring the transmitter to mix a two position switch and a three position switch (giving 6 modes in total).
I have Flysky transmitter, FS-i6X with firmware version 20-Sep-2019 and a 6 channel receiver, FS-iA6B. I would like to map the 3-position switch C and 2 position switch D to channel 5 so that I can get 6 combinations for flight modes. However, the transmitter does not give me any option to map two switches to single channel. I can only map 1 switch to channel 5 leaving me with just 2 PWM combinations.
Other than using the analog dial (which will be a pain to use for setting flight modes), how do I get 6 (or even 3) combinations on channel?
Oct 11, 2020, 11:13 AM
Figured it out. The following thread helped.
https://discuss.ardupilot.org/t/6-mo...s-i6-tx/9920/7
Here are the values that worked for my transmitter:
|End|Points|
|Ch5|Ch6|
|85|100|
|50|100|
|Mix 1|Mix 2|
|Ch5|Ch6|
|Ch5|Ch5|
|-74|74|
|-37|55|
|0|0|
Hope it helps someone.
Oct 25, 2020, 04:16 PM
BoydsEyeView
Billbo1949's Avatar
|End|Points|
|Ch5|Ch6|
|85|100|
|50|100|
|Mix 1|Mix 2|
|Ch5|Ch6|
|Ch5|Ch5|
|-74|74|
|-37|55|
|0|0|
Yep it helped me I'm was wondering how to switch levels on a vtx
Discussion Using channels above 8 for mode switching with Pixhawk/Mission Planner Paul80 Multirotor Drone Electronics 2 May 28, 2016 12:20 PM
Discussion 5 position Flight Mode Switch where to get one? Quadcells Eagle Tree Systems 2 Apr 25, 2016 04:40 AM
Discussion Switching Channels for 3 Channel Flight bkmoulto1 Electric Plane Talk 9 Jan 12, 2016 03:24 AM
Help! Flight mode switch and camera switch with only one channel? Is it possible? PX95 Multirotor Drone Electronics 0 May 01, 2015 11:30 AM
Discussion Taranis 6 Position Switch for 6 Flight Modes w/APM 2.5 & Mission Planner yourbrother Multirotor Drone Talk 1 Oct 26, 2014 10:49 PM
