This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Oct 10, 2020, 05:45 PM
old4570's Avatar
18650 Mini Stick
18650 Mini Stick (7 min 46 sec)
Woke up @ 6AM , to go fly the 18650 battery powered Micro mini stick .
Goal was to test the 7035 prop ..
And it was a huge fail , the 6040E prop was much better .
Problem = Going from the 6040 to the 7035 there was only a few hundred RPM difference .
Sure I got more thrust with the larger DIA prop = BUTT !!!!
RPM + Propeller pitch = SPEED ..
So for the RPM range , the 6040 prop with slightly more pitch gave more speed in flight while the larger 7035 prop may have given more static thrust .
Thrust in this case is not the end all be all due to the low RPM the motor is turning 1s .
What is needed is more propeller pitch .
So broke the prop if you did not watch the video ..
Flying speed was sketchy .
Thankfully the ground was soft and muddy so the only thing to break was the prop .
I will try a 5x5.5 and see what happens .. ( Since I have one )
Update :
5x5.5 Prop = No thrust to speak off ! I lifted the nose up @ full throttle and let go the Mini stick .. It dropped like a stone ..
Rummage around the prop box ..
6x4.5 prop .. = Perhaps a little more hang time than the 6x4E - RPM is down to 5400 rpm ...
I think the Motor KV is too low , anyone contemplating 1s might want 6000KV +
This one is 3800kv .. Multiply by Voltage ( 4 ) = Hmmmm , and then maybe / divide by 50% ( ? )
I think I may need to move on and simply JAM a 2s battery in this model .
And call the 18650 experiment a D+ ( Need more Kv )
One more prop to try ( 6x4.5 )
Discussion DJI Mavic Mini - a 18650 powered drone? Elhungarian Multirotor Drone Talk 19 Aug 15, 2019 01:38 PM
Question INR18650-30Q - 18650 battery for mini talon nilshv Batteries and Chargers 1 Mar 01, 2018 03:27 PM
Discussion FT Mini Arrow on 2s 18650 cells? GravityEvent Flying Wings 0 Jan 12, 2018 11:36 AM
Video Mini quad flying with stick overlay BanniUK Mini Multirotor Drones 0 Sep 30, 2015 05:20 AM
Help! E-flite Mini Ultra Stick vs Mini Pulse XT vs Mini Funtana X vs Extra 260 3D 480 mediclavina Sport Planes 11 Oct 18, 2012 05:57 PM
