Oct 09, 2020, 06:09 AM
sparrow1's Avatar
Fusion question
hello all,
I,m sure this is a weekly question for you all, but i'm just not using the right serch terms.
I am VERRY greeny to fusion, however,after s couple of weeks and a few restarts, i was able to get my custom model from paper into the program. my issue now is i need/want to put it onto a 2d plane for cutting. (Lazer or otherwise) At this point i have no clue how to do it, nor any idea what file format to save it to.
At this time i have a copy of the the model saved to my computer with the default export option.
Thanks for the help,
Oct 10, 2020, 04:00 AM
first what material are you going to use so we know what machine you will need laser router foam cuter
first you will need to setup a work plan on X Y the size of your cutting limits of the machine you are going to use then layout your parts on it when you have it as you wont it is saved or exported to .DXF.
this DXF is then imported in to the software that will create your Gcode or you can send it to a cuter to cut it for you.
search google for free cad cam there sum software that you can play with to make it more understandably
Oct 10, 2020, 12:03 PM
that's gonna hurt...
Fusion has CAM functions - why would you use a separate program?
Oct 10, 2020, 01:17 PM
sparrow1's Avatar
the material will be simple 3/32 balsa, maybe some ply for the main spare if it turns out to weak.
so if I'm understanding correctly, i just need to manually place each part on the desired plane? and export to dxf.
with a bit more reading over the last few days, I've read that people sometimes create a new sketch, and project all the lines onto it then save that, is this something ill need to do as well? or just a personal preference thing?
thanks,
matt
Oct 10, 2020, 01:22 PM
John O'Sullivan's Avatar
As of October 1, Fusion 360 has disabled export of dxf. files
Oct 10, 2020, 01:24 PM
sparrow1's Avatar
heres a pic from the acctual program!
Oct 10, 2020, 04:25 PM
sparrow1's Avatar
Yikes
Oct 10, 2020, 06:22 PM
It's still available - I just did one, doesn't appear to have changed any. I know AutoDesk walked back some of the changes based on feedback from their user forums.
Oct 12, 2020, 04:56 AM
yes i think Autodesk has change the export for autodesk 360 for hobbis
and i forgot that 360 has a integrated cam
so maybe you two can Help with the question asked as i only have a old ver of autocad
sparrow1 i would look for a different cad package freecad is very similar to 360 and has a good forum to help
i prefer direct molding then parametric old school
Oct 12, 2020, 06:08 AM
sparrow1's Avatar
I will look into that!
Sounds intresting what is it?
In the mean time, im finding it dificult to figure out how to move the bodys onto the new sketch plane, any suggestions?
Oct 13, 2020, 03:50 AM
parametric design software such as autodesk 360 / inventor / solidworks / pro engineer / features methods and systems for enforcing parametric constraints sume say a big leering curve
with direct modeling interface such as autocad 2007 or 2020 and rhino 4 / 5 or 6 there are no enforced constraints.
parametric design software the plus is you can change the design simply by typing in a new size and everything up dates it is nice in assembles if you change a part it updates all i fined it very good for engineering projects but for surface modeling not so good.
something like rhino give you more control over surface modeling
or you have the dedicated software for hobby modeling / devcad / CompuFoil3D just 2 that i use not free
there is free software that will do the same job from design to cutting on cnc
sorry can not help you with the 360 i use inventor and autocad in inventor we can import copy and project the sketch to a plan or face
Oct 15, 2020, 05:02 PM
sparrow1's Avatar
Solved!
Oct 28, 2020, 09:27 AM
rgburrill's Avatar
Yes, why use a separate program? Fusion will output gcode from the CAM function.
Oct 29, 2020, 09:05 AM
yes i think Autodesk has change the export for autodesk 360 for hobbies
i prefer direct modelling then parametric old school
Yes, why use a separate program? Fusion will output gcode from the CAM function. ??????????
the cancer is her ???so maybe you two can Help with the question /////asked////// as i only have a old ver of autocad
sum of my old school cad modelling
Discussion FUSION 360 - Questions and Answers sidgates50 CAD/CAM 10 Oct 13, 2019 03:01 PM
Discussion Hitec Fusion 9 Question mwhitman Radios 6 Nov 28, 2006 08:12 AM
Novak Fusion Question racer22 Electric Power Cars 0 Jan 08, 2005 03:47 PM
Question about FUSION controller/ and other cmikecs Electric Heli Talk 2 Apr 09, 2003 02:52 AM
Hello and Corona 120 Fusion 7 question. JWags Electric Heli Talk 4 Apr 04, 2003 09:35 AM
