nexa p47
I am putting together a nexa P47 and was wondering about the esc...it will be a 300kv motor with a 6s set up and was thinking about a freewing 100a esc(from a avainti s edf) is there any reason to not use the freewing and go with the ztw 85a esc? thanks
Ron1950,
The 100A ESC from the Avainti should work. However, Sam Ehab is correct. EDF motors sometimes use different settings. The good news is most ESC are somewhat smart so when a new motor is connected they adjust their settings. However, my recommendation is download the manual and do a factory reset to default values. Then you should have no problems with the ESC connected to your motor. Keep us posted on your progress off your plane. Others may be interested. |
low pass second flight flys great but i had put smaller wheels on it so the grass being wet didnt like the landing roll it nosed over,,watch the stall tests it breaks left for a turn so dont go too slow on yout landings lol. Figured the nose over was from toe out of the struts at the hinge area. New struts and back to the bigger wheels |
Thread Tools | |
Similar Threads | |||||
Discussion | Nexa F-82 Twin Mustang 2100mm | edwen303 | Electric Warbirds | 55 | Feb 10, 2024 03:45 PM |
Discussion | Nexa/ProFly OV-10 Bronco 1800mm ARF | GBLynden | Scale ARF/RTF | 237 | Sep 20, 2023 07:53 AM |
Alert | NEXA G36 Sport 1580mm (62.2 inch) ARF - MotionRC | PittSpecial | Electric Plane Talk | 19 | Apr 03, 2023 02:36 AM |
Discussion | Are Nexa ARFs just rebranded VQ ARFs? | HillbillyJones | Fuel Warbirds | 15 | Jun 07, 2020 10:23 PM |
Discussion | Nexa DHC-6 Twin Otter Canadian Yellow 1870mm (73.6") Wingspan | jobinseattle | Electric Warbirds | 2 | May 11, 2020 04:24 PM |
