This thread is privately moderated by ballistrc, who may elect to delete unwanted replies.
Oct 07, 2020, 10:15 AM
Jumper R1 uninverted smartport works with f4
Today I decided to start a blog here. Over the past few days I managed to modify a jumper R1 to work with uninverted S.port to a Noxe V1 F4. After a bit of investigation I saw a few ppl on this site had tried but failed to modify/connect the rx correctly.
The problem with this receive is that the uninverted point is driven by a c04 inverter. 1 Option would be to replace the C04 with a C05 and a pull up resistor. The easier option is to remove both C04 inverters and place a jumper between pin 2 and pin 5 on pads of both removed C04s.
I've attached a pic of the mods. It is pretty messy due to PCB damage but you should get the idea
Oct 08, 2020, 03:26 AM
Hi, thanks for sharing.
I have the same problem with the Jumper R1 + and the Omnibus F4 nano v6.0
Does your solution work with the R1 + (plus)?
Oct 08, 2020, 03:53 AM
Quick update, I said bridge pin2 and pin 5, that should be pin 2 and pin4. Pin 5 is vcc.
Also if you connect to both TX and RX pin on the FC you should not need a pull up resistor.
Here is a pic shpwing poll from RX and response from FC.
Oct 09, 2020, 01:12 AM
Discussion Jumper R1 frsky compatible 16ch redundancy and telemtry reciever. nigelsheffield Radios 119 Dec 25, 2020 04:27 AM
New Product Jumper R1 Mini Receiver 16CH Sbus RX Compatible Frsky D16 Transmitter Radio Remote Co alex_nikiforov Banggood.com 7 Dec 02, 2020 05:14 PM
Discussion IC engine and FrSky smartport RPM sensor... A coil works! A capacitor works better! Brutus1967 DIY Electronics 173 Oct 26, 2020 07:38 AM
Discussion Jumper R1+ receiver and Succex f4 smart.port telemetry NOT working, nightmare! copterfilms Radios 5 Oct 08, 2020 03:32 AM
