This thread is privately moderated by p901P901, who may elect to delete unwanted replies.
Oct 03, 2020, 06:41 PM
p901P901's Avatar
Wespe
Wing Span 74"
Length 71"
Weight 12 lbs estimate from 3d printing with ABS.
Based off of Esotech Hummingbird http://www.esotec.org/hbird/index.html. Will be using a longer tail like Pattern planes for better controllability. The prop is made from 5ea 20 x 14 prop halves mated to a custom hub. Motor is a Tomcat 160 expected rpm will be 5k on a 6 cell battery. Thrust ratio looks to be 1.3:1
Hover roll control will be fins aft of fan and with tail controls. Expecting 3D aerobatics.
Named this plane after the Heinkel Wespe and the Hummingbird.
Oct 18, 2020, 01:19 AM
p901P901's Avatar
Printed plane estimated AUW was around 17 lbs and static thrust looks to be around 20 lbs. I wanted a higher thrust to weight ratio so I decided to make the plane a wood buildup design. This will droop the AUW to around 12 lbs. I will use the printed shroud. Its weight is 2.2 lbs vs 1.2 lbs for a build up one.
Designed the build up version with devfus 4 and Devwing 3.
