Dec 03, 2020, 03:05 PM
monkeymagic
QuadifyRC.com's Avatar
Discrete receivers
For anything I'm likely to fly further than 1s whoops I have switched to discrete receivers now. A simple $12 frsky XM receiver will give you more range than the video link will allow. I'm a bit of a sucker for making things light weight but I think 0.8g is well spent on a decent receiver.
Dec 03, 2020, 03:35 PM
I agree. I'm planning on adding an R-XSR on mine. The VTX can do 200MW, so I highly recommend upgrading the reciever on this. 0.8g is not going to change the thrust to weight ratio much for this quad and the only time I would recommend a SPI receiver is on an ultralight 1s whoop or something for indoors only.
I was out flying earlier today and my wife commented on how just how powerful and quiet the Crux3 is compared to my other micros. I cannot recommend this quad enough and I'm glad I went with 2s as opposed to 1s 3" since it can handle voltage sag better and is super efficient.
Dec 05, 2020, 06:30 AM
I hope I can be usefull
Dec 28, 2020, 05:55 AM
Jan 06, 2021, 11:17 PM
Nice video Don! It's great to hear the amount of noise each quad makes.
Jan 07, 2021, 07:20 AM
Jan 14, 2021, 12:23 PM
I have a XM Plus receiver lying around but I've never installed one before. Anybody know if there's any issues with disabling the stock spi for the XM?
Jan 14, 2021, 02:38 PM
monkeymagic
I'm running an XM plus in mine:
https://www.quadifyrc.com/reviews/ha...light-no-sweat
Just make sure you use the inverted rx pad (SBUS) as you'd usually do on a F4 board and change the receiver to serial on the UART you are using. Same as a normal discrete receiver.
Jan 15, 2021, 03:10 PM
Just ordered one. With r-xsr. From BG. And 2x TURNIGY NANO-TECH 350MAH 2S 65C LIPO PACK W/XT30 from hobbyking.
Wysłane z mojego LLD-L31 przy użyciu Tapatalka
Jan 16, 2021, 06:05 AM
Originally Posted by Angry Don
Hi everybody !!!
Just release a video I was planning for a moment now...
Comparing the CruX3 to a 1S setup sort of babytooth and 3S tootpick style (on drugs)
Corrected english subtitle, summary, lots of flight footage will talking, sound of each one for comparison and many more...
https://youtu.be/MstHZ7MqYJs
Great vid!👍👍👍
Jan 16, 2021, 11:36 AM
Has anyone tried the crux3 with lion 18650 batteries? I am not sure to choose between 1s or 2s. Drone weights 45gr and each battery is 46g.
Jan 16, 2021, 12:05 PM
Jan 17, 2021, 02:27 AM
Crux3 doesn't have enough KV for 1S.
Voltage even lower on 18650.
2S 18650 = 95g battery should work.
On 2S, about 120g per motor.. 100g because lower voltage. 400g thrust total. 40+95=135g.. 3:1
In general, thrust:weight for motors goes down as they get smaller. Same fixed weight for base and shaft etc.
18650 2S will work much better on 5000KV+ 1303.5 motor.
Jan 17, 2021, 04:30 AM
a.k.a. FPVisnotacrime
Serge Roth's Avatar
The Crux3 is a very docile flyer on 1s, if you pick a light battery, like a 500mah or so. Anything heavy like a 18650 will not work.
Jan 17, 2021, 05:47 AM
I've tried with 2s lion samsung vtc6 batteries. The hover amps are around 5-6A. It hovers at around 50 percent throttle. It files for 15+ min. But I can say that it was the most boring flight I've ever done No throttle authority, it is like trying to steer a boulder. I wouldn't recommend.
One problem I have thought is very limited vtx range around 20-30 meters, the quad gets strong static beyond that. Is there a way to remedy this? Thank you.
New Product Sailfly-X HappyModel (ToothPick version) MultirotorDrones Micro Multirotor Drones 1425 May 02, 2022 06:18 AM
Mini-Review HappyModel Sailfly-X: Cheap "Toothpick-style" FPV quad, how good is it? (review, wip) SoloProFan Micro Multirotor Drones 11 Jul 28, 2019 12:10 AM
Discussion happymodel neo-m8n-1 PINOUT help. flybytim Multirotor Drone Electronics 1 Apr 16, 2016 01:12 PM
Discussion Happymodel Ready to Use Gopro3 Brushless Gimbal No Program Needed copterstar Multirotor Drone Talk 2 Jul 29, 2013 10:07 PM
