Sep 27, 2020, 09:41 AM
Peter D Rieden's Avatar
Question
New Telemetry Parameters?
[Horus X10s Express, OTx 2.3.9, IRSM2.1, Rx6X(access) RxNeuron 80 ESC]
A few days ago I got a new Neuron 80 as a warranty replacement for one that died. I cloned the config of the previous one in BL32Heli and then installed it. When I re-discovered the sensors I found a couple of them (ESC current and BEC current) had changed ID numbers, and two new parameters appeared - "TRSS" and "TQly". Neither seems to be recording any data - the TQly is a constant 0 (with a scale of -1 to +1 and no units) while the TRSS is at a constant 62.0dB.
Does anyone know what these values are? Are they functionality which hasn't been implemented yet, or what?
PDR
Sep 27, 2020, 10:31 AM
Carbo (-nator) ;-)
TRSS and TQly are MPM sensors for telemetry RSSi and telemetry LQ. Seems FrSky used this IDs also.
Sep 27, 2020, 11:02 AM
Ah. It is possible that I may have inadvertently turned on my external RF at some point, so I'll re-discover the sensors and see if they're still there!
PDR
Sep 30, 2020, 04:58 PM
After experimenting this evening it turns out that's exactly what I must have done, so I'm sorry about that!
But on the upside it means that I have established the X10S can receive telemetry from the internal (ACCESS) module and the External (Jumper 4in1) module simultaneously. I don't know why I might want to do that, but I shall file the information away in case it ever becomes useful!
PDR
Discussion APM 2.8 I2C port parameters and MinimOSD Sakuse FPV Equipment 4 May 15, 2019 03:02 PM
Discussion Start parameters for KingTech K140G helicobruno Jet Turbines 10 Aug 30, 2018 10:41 AM
Discussion Hobbywing Platinum V4 ESC Governor Parameters P & I lexpowers Electric Power Systems 1 Jan 18, 2016 02:46 AM
Question CC3D Board trouble saving parameters DaniloGarciaH Flying Wings 2 Jan 04, 2016 06:50 AM
Discussion Dynamometer test parameters for brushed micro motors Novgorod Multirotor Drone Electronics 1 Nov 14, 2015 02:18 PM
