NewBeeDrone Tool Kit - Now With Prop Tool!
No drone pilot is complete without a good set of tools to repair and swap parts out on their aircraft.
Get Your Tools in Order
No drone pilot is complete without a good set of tools to repair and swap parts out on their aircraft. The NewBeeDrone Tool kit is quality stuff and makes it convenient to take with you in your pack so you can always have the tool you need when you need it. This kit was sold previously without the prop tool, but now one is included. If you ordered this tool kit in the past and would like the prop tool you can contact them and they will include the prop tool in your next order. Here's a list of what it comes with.
Included tools:
  • Premium Tool case
  • Hex driver 1.5mm
  • Hex driver 2.0mm
  • Hex driver 2.5mm
  • Soldering Iron
  • Power Cable
  • Flux Pen
  • Solder
  • Soldering Iron holder with sponge
  • Precision Tweezers
  • Precision wire cutters
  • Precision Phillips Screwdriver
  • Prop Tool
Soldering Iron Specification:s
  • Power: 65W
  • Power interface: 5.5 x 2.5
  • Working voltage: DC12-24V, (inner positive and outside negative)
  • Work current: >=1.5A
  • Temperature range: 220-400℃
  • Size of the control handle: 110 x 16 x 15mm
  • Tip size: 115 x 5.5mm
  • Weight: 28g
  • This solder iron comes with a XT60 Plug power cable, it will require a power source such as battery from 4S to 6S or a AC power wall adapter.
So what do you guys think? Is this the perfect tool set or would you add more to it? Let us know in the comments.
Sep 28, 2020, 12:51 AM
Technica's Avatar
Looks like a solid kit. Only thing I'd add to it is a prying tool. I usually use a few different size guitar picks.
New Product Kingkong 3/4/5/6" Props Now with Tri,Quad and Hexa-Blades! MrE_fz Mini Multirotor Drones 52 Jul 04, 2017 07:05 PM
New Product Prop tightening tool helps you assemble prop quicker Eason N Multirotor Drone Talk 8 Jan 08, 2016 12:35 AM
New Product Prop tightening tool help you assemble prop quicker Eason N Mini Multirotor Drones 39 Dec 26, 2015 07:02 PM
New Product Prop tightening tool help you assemble prop quicker Eason N FPV Racing 7 Nov 11, 2015 11:41 PM
