The NEW E-flite V1200
Look Good, Fly FAST and Fly Smart!
E-flite V1200
The V1200 is faster than any prop-driven E-flite® airplane yet! It can reach level-flight top speeds of 140+ MPH on 6S, or 100+ MPH on 4S, right out of the box. It’s also equipped with flaps, retracts and Smart to deliver an experience like no other!
See more info below and on the product pages via this link (NOTE: The link will not work until the web site is updated later this morning):
https://www.horizonhobby.com/search?...=&lang=default
FAST AND “SMART”
Look good, fly fast AND fly Smart with the E-flite® V1200! Larger and even faster than the popular V900™, it comes factory-equipped with operational flaps and retracts, along with a high-performance brushless power system that lets you choose how ballistic you want to be. Level-flight top speeds of up to 100+ MPH are possible with 4S batteries. Or reach up to 140+ MPH using common 6S 3200–7000mAh packs! Along with head-spinning speed, the V1200 offers unexpectedly stable slow flight and locked-in precision aerobatic capabilities. It's also equipped with a 100-amp Spektrum™ Avian™ Smart ESC, and the BNF® Basic version is equipped with an AR637TA receiver that offers full-range telemetry including real-time battery voltage, current, temperature and more when using compatible transmitters.
Overview
BUILT FOR SPEED, STRENGTH AND STYLE
Grab the sticks to fly the fastest prop-driven E-flite® airplane yet! With 4S 3200–5000mAh batteries and the factory-installed brushless power system, the V1200 reaches up to 100+ MPH in level flight— making it suitable for intermediate pilots with some high-speed flying experience, especially when utilizing the BNF® Basic version’s optional-use SAFE® Select technology. Experienced pilots can unleash level-flight top speeds up to 140+ MPH with popular 6S 3200–7000mAh batteries! The Spektrum™ Avian™ 100A Smart ESC lets you speed with confidence, knowing all is well with the power system and battery from the real-time telemetry data sent via compatible receivers (such as the BNF® Basic version’s AR637TA) to Spektrum AirWare™ equipped transmitters.
Speed and aerobatic enthusiasts will love the locked-in precision of the six digital, metal-geared servos and ball-link equipped linkages. Operational flaps improve slow-flight performance and allow for shorter takeoffs and landings. Electric retracts with sprung wire struts let you fly from paved, packed dirt or shorter grass surfaces at any suitably sized fields. The sleek airframe is composite-reinforced throughout and is molded in new, higher-density EPO that delivers a stronger and stiffer airframe with a smoother, dent and damage resistant surface. Plus it’s factory-finished in a vibrant, high-contrast trim scheme for improved visibility and orientation. No glue is required for assembly, and a total of six screws install the stabs plus the one-piece wing that attaches and removes easily for convenient storage and transport. That means you can be ready to enjoy a flying experience unlike any other in less time than it takes to charge a battery. It’s easy to look good, fly FAST and fly Smart with the V1200!
Exclusive Technologies (BNF® Basic version only) The V1200 is equipped with exclusive Spektrum™ AS3X® and SAFE® Select technologies. AS3X works behind the scenes to smooth out the effects of wind and turbulence to deliver a locked-in feel that makes it seem like you're flying a much larger airplane. Optional-use SAFE Select offers pitch and bank angle limits along with automatic self-leveling that can be turned on and off at the flip of a switch! And if you don't want to enable the SAFE Select features, simply bind the receiver normally and only AS3X will be active.
Smart Technology The exclusive Spektrum™ Avian™ Smart ESC provides a variety of real-time power system related telemetry data including motor RPM, current, battery voltage and more via compatible receivers (including the AR637TA) and Spektrum AirWare™ equipped transmitters (including the DX6e and 8e, DX6 G2/G3 and 8 G2, the DX9, iX12, iX20 and others) while you fly.
Versatile Brushless Power The V1200 is factory-equipped with a high-power brushless power system that gives you the option to choose just how fast you want to go. Simply drop in a 4S battery to reach level-flight speeds up to 100+ MPH with the included APC 10x8E propeller and aluminum spinner. Or, to go beyond that and reach top speeds up to 140+ MPH, install a 6S battery—no modifications or upgrades necessary!
Strength and Precision Speed is nothing without the right balance of strength and precise control. The V1200’s stunning and sleek airframe is molded in special, higher-density EPO that results in a stronger and stiffer airframe with a smoother, dent and damage resistant finish. It’s also composite reinforced including multiple carbon fiber spars throughout the wing, fuselage and tail. Plus it’s equipped with digital, metal-geared servos that deliver the precise control and reliability you need to enjoy flying FAST flight after flight.
Functional Features Operational flaps offer improved slow-flight capability and performance while also making it possible to take off and land in shorter distances and at slower speeds. Reliable electric retracts with sprung wire struts make it possible to fly from a variety of surfaces including pavement, dirt and grass.
Easy Assembly No glue is required for assembly and you can have the V1200 ready to fly in less time than it takes to charge a battery! With a total of six screws, the stabs and the one-piece wing bolt into place and can easily be removed for convenient storage and transport.
Bind-N-Fly® Completion Level Advantage Already own a Spektrum™ transmitter? Bind-N-Fly® (BNF®) aircraft make getting into the air quickly and with the best control experience possible easier than ever. They come out of the box with the power system, servos and a Spektrum 2.4GHz receiver installed so all you need to do is bind the receiver to a compatible transmitter, finish any final assembly, and fly!
This Bind-N-Fly Basic model is equipped with a Spektrum 2.4GHz DSMX® receiver featuring AS3X® (Artificial Stabilization–3-aXis) technology that works behind the scenes to smooth out the effects of wind and turbulence so you enjoy a sense of stability and precision that makes it feel like you're flying a much larger, expertly tuned aircraft.
If this is your first model of its type, or you want an extra margin of safety while familiarizing yourself with the airplane, you can enable the optional-use SAFE® Select flight envelope protection technology built into the receiver. No programming is required. Simply change up the binding sequence as directed in the manual.
With SAFE Select enabled, you get:
Pitch and Bank Angle Limits These envelope limits keep the airplane from rolling or pitching upside down. They also prevent excessive climb or dive angles.
Automatic Self-Leveling The airplane instantly returns to and holds level flight when the sticks are released and in the center position. It’s also helpful for keeping the wings level during takeoffs/launches and landings.
Easy Switch Assignment—No Complex Programming Required The simple procedure for assigning a transmitter switch to turn SAFE Select features on and off doesn't require any complex programming and takes just a few seconds.
If you don’t want to enable the SAFE Select features, just bind the receiver normally and it will function like a standard AS3X receiver.
Plug-N-Play® Completion Level The Plug-N-Play® (PNP) version comes out of the box with a factory-installed power system and servos that are ready to connect to the compatible receiver of your choice (sold separately), plus the transmitter and battery you provide (also sold separately). Simply install the receiver, finish any final assembly, and fly!
Key Features
  • The FASTEST and Smartest prop-driven E-flite® airplane yet
  • A scaled-up version of the popular V900 equipped with flaps, retracts and Smart technology
  • Level-flight top speeds up to 100+ MPH with 4S batteries and up to 140+ MPH with 6S batteries
  • Compatible with 4S, 5S and 6S batteries from 3200-7000mAh to deliver a wide range of performance and flight times
  • Extremely wide flight envelope from unexpectedly stable slow-flight to locked-in precision aerobatic capabilities and beyond
  • Factory-installed high-RPM brushless outrunner motor plus APC 10x8E prop and an aluminum spinner
  • 100-amp Spektrum™ Avian™ Smart ESC provides real-time battery voltage, temperatures, motor RPM and other data via compatible receivers and transmitters
  • Spektrum AR637TA receiver with full-range telemetry and industry-leading DSMX® technology (BNF Basic version only)
  • Easy to fly with innovative and optional-use SAFE® Select flight envelope protection (BNF Basic version only)
  • The unmatched stability and locked-in feel of exclusive AS3X® technology (BNF Basic version only)
  • Six factory-installed digital, metal-geared servos with precise ball-link equipped linkages
  • Functional flaps for shorter takeoffs and landings plus improved slow-flight performance
  • Reliable electric retracts with sprung wire struts for operation from a variety of surfaces including grass
  • No glue required for assembly – six bolts and it can be ready to fly in less time than it takes to charge a battery
  • Strong and easy to install/remove one-piece composite reinforced wing with V2 hands-free servo connection system
  • Bolt-on wing and stab for extremely quick and easy assembly/disassembly and for convenient storage/transport
  • Higher-density EPO results in a stronger and stiffer airframe with a smoother, dent and damage resistant finish
  • Factory-finished in a vibrant, high-contrast trim scheme for improved visibility and orientation
  • Large and convenient, magnetically-secured top hatch and large battery compartment
Specifications
  • Wingspan: 47.25 in (1200 mm)
  • Overall Length: 43.0 in (1091 mm)
  • Flying Weight: 5.8 lb (2.63 kg)
  • Motor: Brushless Outrunner (installed)
  • Speed Control: Spektrum™ Avian™ 100A Smart Brushless (installed)
  • Servos: (6) Digital Metal-Geared (installed)
  • Radio: Full-Range 6-7+ Channel Spektrum™ DSMX®/DSM2® compatible transmitter (sold separately)
  • Receiver: Spektrum™ AR637TA 6-Channel (installed, required for PNP version)
  • Battery: 4S 14.8V to 6S 22.2V 3200-7000mAh LiPo with EC5™ or IC5™ Connector
Needed to Complete
  • Full-range 6-7+ channel Spektrum™ DSMX®/DSM2® compatible transmitter (6+ channel transmitter/receiver for PNP version)
  • 4S 14.8V to 6S 22.2V 3200–7000mAh LiPo with EC5™ or IC5™ Connector
  • Compatible LiPo charger
Sep 24, 2020, 01:19 AM
E-flite® V1200 1.2m w/Smart PNP & BNF Basic Airplane (4 min 31 sec)
The V1200 is in RealFlight 9.5, which is also being announced today! Best of all:
If you purchased RealFlight 9 at any time, you will receive an online update to 9.5 at no charge! Internet connectivity required to download the update after RealFlight 9.5 is released on October 1st, 2020
RealFlight® 9.5 RC Flight Simulator (0 min 55 sec)
On The Fly:
On The Fly: Eflite V1200 (14 min 25 sec)
Videos from Pilot Ryan Media: https://www.youtube.com/user/RCAirTrainingCommand
Flights including grass ops:
E-flite V1200 1.2m w/Smart BNF Flown on 6S and 4S 4000 (GRASS OPS) (15 min 16 sec)
Flown by Bobby K:
E-flite V1200 1.2m w/Smart BNF Flown on 6S by Bobby K (5 min 56 sec)
Video from Chris Wolfe/The RC Geek: https://www.youtube.com/channel/UC5q...xwMlHf_A-XZGlA
From the Field -- E-flite V1200 1.2m BNF Basic with Smart Assembly & Flight Review (11 min 31 sec)
Videos from Rich Baker/RCINFORMER: https://www.youtube.com/user/RCINFORMER/featured
Unboxing, assembly and setup:
E-flite V1200 Unbox, Assembly, Setup & flight clips By: RINFORMER (43 min 4 sec)
4S and 6S flights from paved runway:
E-flite V1200 6s & 4s paved runway demos By: RCINFORMER (39 min 50 sec)
Grass ops:
E-flite V1200 Grass Operations By: RCINFORMER (19 min 16 sec)
E-flite V1200 1.2m BNF Basic with Smart (7 min 21 sec)
How to UNLOCK your Spektrum AR637TA - Open Beta Update (13 min 17 sec)
More videos coming soon!
Sep 24, 2020, 01:53 AM
Cool plane.. Unfortunately I'm sure that in Europe it will cost something ridiculous..
Sounds like somebody was listening in the EFXtra, V900 and probably other threads when I and others were wishing for an upsized version for 6S...
Nice to see them do it, but again, the price is going to be in la la land.
Sep 24, 2020, 06:04 AM
PSALM 14:1
Sammy70's Avatar
Wow, VERY cool Jason!!
I love everything about it EXCEPT the blue paint scheme
Blue/white paint schemes tend to disappear against blue/white skies
Sep 24, 2020, 06:34 AM
CR5
CR5
All out of icing sugar
Been on the fence for months on getting the V900, this one is more likely to end up in the hangar.
Retail price will be the deciding factor.
Sep 24, 2020, 07:44 AM
Fly Eat Sleep Repeat
Andy852's Avatar
The specifications do not list the propeller used, nor does the manual.
Weird.
Sep 24, 2020, 08:26 AM
MRC Fanboy (per Jason M.)
JamesonC's Avatar
There are a few planes coming down the pipeline at HH that I am really excited about and this is for sure one of them! I love my V900 and will certainly add this one to the collection!
Side note- Jason, well done on capturing true speeds with radar and GPS in levelish flight! Much much better than the Havoc ordeal!
Can't wait to get this one!
Sep 24, 2020, 08:59 AM
Mattfly's Avatar
Weird.
It uses an APC 10 x 8e
Thanks.
Matt Andren
Product Development
Horizon Hobby
Sep 24, 2020, 09:27 AM
Does the new V1200 fixed the tail rigidity and strength issue on v900?
Sep 24, 2020, 09:33 AM
Hubert1's Avatar
This looks really cool, $370 for bnf with AR637T isn't too bad I guess, I haven't looked at recent bnf planes, is the AR637T now standard or is there some other reason for this particular rx?
Sep 24, 2020, 10:40 AM
Although the overall design/outline was scaled up from the V900, the internal structure is all-new in the V1200. It's also molded from new, higher-density EPO, which along with the additional composite reinforcements throughout the fuselage and wing, ensures the strength and rigidity is what it needs to be to handle speeds up to 140+ MPH!
The AR637TA offers full-range telemetry capability plus full Smart ESC compatbility, and also has forward-programming capability like the AR637T (see the video below for more info on how to make that possible!) which is a big step up over the AR636 that was included with RTF/BNF models for many years. Not every future release will include the AR637TA (some will include the new AR630 and other new model receivers), but the AR636 is EOL and will not be included with any new RTF/BNF models in the future.
Sep 24, 2020, 10:54 AM
Daren71's Avatar
Very nice!
Sep 24, 2020, 11:26 AM
Added videos from Ryan and Rich to the second post!
Grass op:
Sep 24, 2020, 11:30 AM
BTW, for those who haven't seen it yet, there's also a combo that includes the BNF Basic version plus a Spektrum Smart 6S 5000mAh 30C battery at half price! This combo is ONLY available for pre-orders placed on or before 10/16/20:
https://www.horizonhobby.com/product...EFL12350C.html
Sep 24, 2020, 11:43 AM
My biggest issue with all these "reviews" and it looks like a nice aircraft, but all these reviewers are financially incentivized to talk great about the aircraft, not even were improvements could be made or anything negative ... what happened to unbiased and neutral reviews HH? you afraid it won't achieve 140mph like your havoc xe?
Article The NEW E-flite Night Timber X 1.2m BNFB/PNP...Smart STOL PLUS 3D — ALL DAY AND NIGHT Jason M Electric Plane Talk 1366 Yesterday 08:33 PM
New Product The NEW E-flite Twin Otter 1.2m BNF Basic/PNP...Versatile and Easy To Fly Scale Twin! Jason M Electric Plane Talk 1941 Yesterday 12:45 PM
News Fly Fast with the new E-flite V900 Jim T. Graham Electric Plane Talk 3922 Sep 12, 2021 12:19 AM
Discussion E-flite 4-site - looks like a great plane - can't wait to fly it! earthling1984 3D Flying 30 Nov 28, 2009 07:19 PM
Build Log E-Sky E-Smart 600 Class E-Copter build & Fly Gary Morris Large Electric Helis 82 Jul 04, 2009 09:06 PM
