Extreme Flight - 60" Edge 540T-EXP V2 has Arrived!
Introducing the brand new Extreme Flight RC 60 inch Edge 540T EXP V2 ARF
60" Edge 540T-EXP V2 Blue/Yellow
From Chris Hinson
At long last the V2 60" Edge 540T EXPs have arrived! Probably the best airframe to learn the basics of 3D flight after a foamy, the Edge is easy and forgiving yet completely capable as your skills progress.
Long regarded as the best aircraft to learn the basics of 3D flying, the Edge 540T is very forgiving for novice 3D pilots yet fully capable as your skills progress. The Edge incorporates carbon fiber and G10 composites into the structure of the airframe, resulting in a lightweight, yet twist free structure capable of handling extreme aerodynamic loads. Carbon and G10 are used in high stress areas such as the landing gear mounting structure and fuselage longerons to provide enormous strength and durability.
The removable wing panels are mounted on a carbon fiber wing tube and are fastened to the fuselage with our new quick mount wing latch system. All control surfaces are pushrod driven with short linkages and use ball links for slop free actuation with no binding. Optional Side Force Generators are included and add to the already generous side area, increasing yaw axis authority and adding stability in all angles of sideslip. Expertly painted fiberglass cowl and wheel pants and 2 gorgeous high visibility Ultracote color schemes add the finishing touches and make this an airplane that you will be proud to show up at the flying field with. Couple the Edge with the Xpwr 22 and be prepared for ballistic vertical performance!
Specifications:
  • Wingspan: 60 inches
  • Length: 58.5 inches
  • Wing Area: 735 sq. in.
  • Weight: 5 - 6lbs
Power System
  • Motor: Xpwr 22CC Motor
  • ESC: Airboss 80
  • Prop: Xoar 16 x 7
  • Battery: 6S 3300- 4000mAh LiPo
Spinner
  • Spinner: EF Cyclone 63 mm spinner included!
Learn More
Head over to Extreme Flight for more info!
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 14500 Sep 12, 2020 08:42 PM
Article Exclusive Extreme Flight Interview - 85" Edge 540T, 60" Edge v2, Extra EXP 48" v2 Jim T. Graham 3D Flying 3 Apr 19, 2020 11:15 AM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 250 May 26, 2019 04:07 PM
Discussion EF 60" Edge 540T-EXP - Blue/Yellow (Opinions) jobinseattle 3D Flying 10 Jul 16, 2017 03:27 PM
Help! Extreme Flight 60" Edge 540T EXP or 60" Extra 300 EXP Liberty10 3D Flying 12 Aug 10, 2012 10:36 PM
