This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Sep 22, 2020, 07:09 AM
Video
Review & Testing - RacerStar BR2212 1800kv, BR2212 1400kv, BR2216 1400kv Motors
Fun Cub 1100mm Wingspan EPO Trainer Airplane Kit
https://www.banggood.com/custlink/m3Gyp5QwBf
Banggood GCRC
https://www.banggood.com/custlink/GmDmQ1nVkO
Motor Thrust Data Files:
https://groundcontrolrc.com/ftp/moto..._1400kv_3s.pdf
https://groundcontrolrc.com/ftp/moto..._1800kv_3s.pdf
Here is a link to the Fun Cub 1100mm Playlist:
https://www.youtube.com/playlist?lis...jUlSv6hkrevtUK
Here is a link to the Video:
https://www.youtube.com/watch?v=LMKA1rjDdeM
Here are links to all the Components I picked out for this Kit Plane:
Racerstar BR2212 1400KV 2-4S Brushless Motor (Primary Motor)
https://www.banggood.com/Racerstar-B...47791920140372
APC 10x3 2-Blade Sport Composite Prop (BR2212 1400kv - Primary Prop)
https://www.apcprop.com/product/10x3/
APC 10x4 2-Blade Sport Composite Prop (BR2212 1400kv - Alternate Prop)
https://www.apcprop.com/product/10x4/
Racerstar BR2212 1800KV 2-4S Brushless Motor (Alternate #1 Motor)
JXF Poly Composite Propeller 8x4 (2pcs) (BR2212 1800kv - Primary Prop)
https://hobbyking.com/en_us/jxf-poly..._asc=897416588
Gemfan 8040 Propeller for RC Airplane Fixed-wing Aircraft 1 Pair (BR2212 1800kv - Alternate Prop)
https://www.banggood.com/Gemfan-8040...47791920140372
Racerstar Racing Edition 2216 BR2216 1400KV 2-4S Brushless Motor - Clockwise Screw Thread (Alternate #2 Motor *The Threaded Shaft is actually 6mm)
https://www.banggood.com/Racerstar-R...47791920140372
TGS Precision Sport Propeller 9x3.8 (BR2216 1400kv -Primary Prop)
https://hobbyking.com/en_us/tgs-prec...asc=7285772039
ZOHD DART XL Extreme FPV RC Airplane Spare Part Propeller 9x4.5 Inch for Enhanced Version (BR2216 1400kv - Alternate Prop)
https://www.banggood.com/ZOHD-DART-X...47791920140372
FMS Predator 20A Brushless ESC With 2A Linear BEC BECT JST Plug for RC Models - JST (Alternate)
https://www.banggood.com/FMS-Predato...47791920140372
Volantex Easy-Plug 30A 2-4S Brushless ESC With XT60 Plug (Primary)
https://www.banggood.com/Volantex-Ea...47791920140372
FMS Predator 40A Brushless ESC With 3A Switch BEC XT60 (Alternate)
iRangeX RM601 2.4G 7CH Micro DSM2 DSMX Compatible Receiver With PPM Output - with pin (Primary)(you need a receiver that supports your transmitter)
https://www.banggood.com/IRangeX-RM6...47791920140372
CM703 2.4G 7CH RC Receiver With PPM Output (Alternate) (you need a receiver that supports your transmitter)
https://www.banggood.com/CM703-2_4G-...47791920140372
4X Racerstar DS1202MG 12g 180° Metal Gear Digital Micro Servo (Primary)
https://www.banggood.com/4PCS-Racers...47791920140372
4X SG90 Mini Micro Digital Servo 9g (Alternate)
https://www.banggood.com/4X-TowerPro...47791920140372
4X Racerstar SG90 9g Micro Plastic Gear Analog Servo (Alternate)
Gaoneng GNB 11.1V 1300mAh 3S 40C XT60 Plug Lipo
https://www.banggood.com/Gaoneng-GNB...47791920140372
You Can Help Support Us By Using Our Affiliate Links To The Products Above. A small commission (At No Cost To You) helps us buy more items to Test & Review.
#GroundControlRC #GlueAndFly #ScratchBuildPlanes #FunCub #FunCub1100mm #FunCub1100mmKit #RacerStar #BR2212 #BR2216
See you in the Air!
Ground Control RC™ Glue & Fly™ Series Scratch-Build Planes
Consider Supporting Our Channel by becoming a Patron at: https://www.patreon.com/groundcontrolrc
Patrons of the Channel will have Exclusive access to Aircraft Plans & Content!
See Us On Youtube | Patreon | RCGroups
New Product Racerstar Racing Edition BR2216 810KV 1400KV 2-4S Brushless Motor Disguession Thread BGjim Multirotor Drone Power Systems 10 May 21, 2018 10:04 AM
New Product Racerstar br2212 900/1000/1800/2200/2450 KV Motor--FREE REVIEW BG Tobey Power Systems 7 Apr 16, 2017 11:31 PM
New Product Racerstar BR2208 1100KV 1250KV 1400KV 1500KV 1800KV 2600KV Motor---------Free Testing BGjim Multirotor Drone Power Systems 14 Feb 19, 2017 11:28 AM
