Build pictures more from Doroshenko
Deviations NG2M:
This not maximum throws !! Ailerons Up - 8-9mm Ailerons Down - 4-6mm Flap Down - 30-35mm (stabilizer down , when flap down 6-7mm) Thermal - ailerons down 3-4 mm (stabilizer down 2mm) Speed - ailerons UP 2-3mm (stabilizer up 1mm) Stabilizer Up 8-9mm Down 4-6mm CG 84-88mm ImagesView all Images in thread |
Hello what is the weight of your NG2M ready to fly?
According to Neil at Hyoerflight, who’s normally spot on, 620g flying.
Question on camber for cruise mode.
So here is a question... When setting up the initial camber for cruise mode, at the trailing edge where the aileron meets the fuse, the aileron is much thinner than the formed wing profile on the fuse. Should the aileron follow the top of the wing profile of the fuse (like in the pictures) , or follow the paint line (that looks to be about the middle of the TE), or somewhere else? Thanks in advance.
What is the weight of your model ? Is it electric ? |
Reason: forget something
Push rods dimensions
Hi all,
Please can you provide me with the dimensions of the ailerons and flaps push rods length. I ordered a NG2m still waiting for delivery and l would like to buy the IDS system for surfaces control. So l can move up and l will receive everything together. Thank you |
Wing picture
See attached picture
oh ok thats nice .. I did not know that it existed a flap version . Let me know how it flies.
Me neither. I've been looking at this plane for a long time and actually rather liked the simplicity of flaperons. Once we are talking about 6 servos, given the cost, it starts to make more sense to look at a 3m plane instead.
You are right especially and since the NG2M flies really extremely well with flaperons why bother?
Build Log | BMJR Models CONDOR - 2M R/C Glider Electric | Joe Pierson | Vintage & Old-Timer Designs | 67 | Jul 05, 2023 05:55 AM |
Discussion | High glide ratio big electric gliders (2m+) for FPV (20 to 1 or better)? | marcmerlin | Electric Sailplanes | 26 | Dec 11, 2021 08:18 AM |
Discussion | Hacker A10-7L +4.4:1 Gearbox in a 2m electric glider? | aerotony | Electric Competition Soaring-F5J, eF3K, F5K, ALES | 28 | Apr 02, 2017 09:15 AM |
Video | My First Electric Glider ST Model DG-1000 | jegouvrc | Electric Sailplanes | 3 | Apr 25, 2016 08:16 PM |
Discussion | Hacker A10-7L +4.4:1 Gearbox in a 2m Electric Glider? | aerotony | Electric Sailplanes | 1 | Oct 06, 2015 12:09 AM |
