May 15, 2005, 10:52 PM
Dumas Wellcraft’s 38 Scarab KV
I'm thinking of getting the 55"Dumas scarab, does anyone know about this kit, and how the build goes? It will be my first gas boat, thinking of a 25cc homelite engine from prather. Or would i be better off with a OS 81 nitro engine?
Derek
May 16, 2005, 05:40 PM
Derek;
I have this hull. If you are looking for speed its not the perfect hull. Mine completed wieghted in at 16 lbs. I used the Dumas hardware which was a mistake. The stuff is junk. On the upside the boat is solid as a rock on the water. I used an A100 PIP glow engine which puts out about 8 HP (tuned perfect). I am working my way up to a Prather S275 prop. I am hoping to get around 40+ MPH when setup properly. The kit complete with good instructions.
As far as your choise of engines, I would say to go for the best power to weight ratio. This hull can handle lots of power.
Jim
May 16, 2005, 11:26 PM
How easially does the build go on this boat?
is there a better hardware kit to use than the dumas kit? what were the un-satisfactory things about the dumas hardware kit?
May 19, 2005, 11:22 PM
aeronavale's Avatar
As mentionned earlier, it is pretty much straight forward
This hull present itself as a good candidate to scale.
Here is the stern of my Scarab 45 while it was still under construction.
May 21, 2005, 08:26 PM
The build had no real surprises, from memory the only thing that I did not like was that there was a lot of work involved in building up the hatch frame and the hatch itself. Getting it to fit and look good took a lot of time.
The Dumas running gear (strut and 1/4" flex shaft) is typical to a lot of others available. The strut does not look as good as some others but it works the same in the end.
The dumas rudders are made from a stainless rod silver soldered to a stainless blade. You could make it yourself. I have swapped it out for one made by PIP with a built in water pickup.
If you are starting a new build get a running gear package from another supplier. Here are a couple of typical links. I can not recomend most since I have not used them.
http://www.insaneboats.com/
http://www.mhzusa.com/xtdoc/
Mar 28, 2010, 04:37 PM
Running jokes into the ground
b-29er's Avatar
I may be getting a Wellcraft Scarab from a friend, but I am not sure about the engine. What kind of engine would I use? Would electric be a possibility?
For Sale dumas KV-38 scarab 55" 48chebbie Boats (FS/W) 8 Dec 18, 2005 11:21 PM
Dumas Wellcraft’s 38 Scarab KV dds7197 Scale Boats 12 May 16, 2005 11:39 PM
Dumas Wellcraft’s 38 Scarab KV dds7197 Dock Talk 0 May 15, 2005 10:53 PM
F/S 38 HE-1100 Cells Loose never used GoodTill Aircraft - Electric - Airplanes (FS/W) 3 Feb 23, 2003 12:32 PM
Sikorski S-38 LenBFP Scale Kit/Scratch Built 7 Apr 05, 2002 01:37 PM
