This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Sep 20, 2020, 11:21 PM
Mini-HowTo
Mini Apprentice Mods
Mike K purchased a used Mini Apprentice from Mike B. This 48 span model will be able to handle winds better than his 4 ounce UMX Turbo Timber. I programmed his DX6 and trimmed her out with SAFE OFF then turned SAFE On. Every maneuver checked good except for aileron to rudder mix that I put into the transmitter. I did not know that it was already programmed into the AR636 A receiver. I think she went cross control similar to the larger Apprentice with the older Apprentice SAFE receiver. There was minimum damage and after replacing the stock prop with an APC 9/6E and inhibiting the TX aileron/rudder mix she flew fine. I like her more than the larger Apprentice because of the Re designed stab. This Apprentice came without a nose wheel and had been in a nose down crash as evidence from the compression wrinkles and a new cowl. I brought her home to make some improvements such as:
1. Adding a steerable tailwheel
2. Programming the ESC prop brake
3. Trimming the stock spinner to fit the APC9/6 prop
4. Glueing the bindplug receptacle to the fuselage side
5. Moving the 18 amp ESC forward to the motorway for more cooling air
6. Adding cloth covered bungee bands to replace the 6 rubber bands.
See pics and notes
Discussion HMDVR Mini DVR Headplay Goggles Mod issue with diagonal lines - interference? markm75 FPV Equipment 8 Jul 18, 2017 07:50 AM
Build Log Modded mighty mini arrow(FT) mokermeister Foamies (Scratchbuilt) 6 Mar 30, 2017 03:00 AM
Discussion Newbie learning on H8 Mini w/mods cbnlnk121 Beginner Multirotor Drones 5 Feb 15, 2016 07:08 PM
Discussion Traxxas Mini Revo Battery Compartment Mod For Larger Lipos KevinMillard Off-road Cars 0 Jan 31, 2016 08:10 AM
