Enjoy terrain-commanding Monster Truck excitement with the jaw-dropping power and 50+ MPH brushless performance of the ARRMA® GRANITE™ 4X4 3S BLX Monster Truck. Precision aluminum, tough steel and composite materials come together for an easy-to-maintain, super-durable vehicle design that’s now upgraded for even greater performance and durability.
The GRANITE™ 4X4 3S BLX RTR is DESIGNED FAST, DESIGNED TOUGH — built for exciting bashing speeds and extreme, all-terrain toughness. New features that enhance its unstoppable performance include a stronger chassis and retained hinge pin plates; steering with more clearance for stones; a castellated slipper pad and sliding gear mesh; and rubber-shielded bearings throughout.
It also now includes a Spektrum™ SLT3™ transmitter and SLR300 receiver. The transmitter is ergonomically designed for long periods of fatigue-free bashing and has a foam wheel for precise fingertip control, plus an improved hand grip and trigger feel. New bashers will be able to set throttle limits at 50% or 75% until they are ready to use the full speed potential. The SLT3™ is compatible with Tactic® SLT™ receivers to run other RTR vehicles you may own, and includes a third channel to control optional features such as lights and winches on models that have them.
ARRMA® now powers the GRANITE™ 4X4 3S BLX with a brushless system featuring its BLX100 ESC and the Spektrum™ Firma™ 3200Kv brushless motor. The combination provides incredible torque, acceleration and speed. The transmission and chassis are ruggedly engineered to take full advantage of the electronics’ power.
It has the ingenious modular design perfected by ARRMA® engineers for easy component access and maintenance. The power module, with improved dirt management, consists of the motor with ARRMA® heatsink and cooling fan, plus motor plate, slipper clutch assembly and gear cover. The power module can be detached from the chassis as a complete unit by removing just one screw. With the power module removed, the slipper clutch can be reached easily for adjustments by taking out three screws that attach the gear cover. The gear ratio can be finely tuned as the power module now uses a sliding motor mesh design.
A two-piece molding screwed to the truck’s chassis serves as its electronics module, containing a waterproof receiver box, servo mount and ESC tray. The SLR300 receiver mounts inside the receiver box for protection from dirt and moisture. The ultra-compact ESC is screwed to the top of the module, allowing quick access to the on/off switch, while the servo mounts to the side. All three components can be removed together, quickly and easily.
The differential module houses each differential unit in an innovative yoke design. Only eight screws need to be removed to release the front and rear yokes. The power module can then be detached, allowing you to pivot the gearbox cases for differential access. The GRANITE™ 4X4 3S BLX RTR comes brushless-ready with 37T 1.35mod diffs with silicone O-rings. The large gears can withstand huge torque, and internal metal gears have been chosen for reliability during extreme bashing.
Its full-time 4WD transmission uses strong front, rear, and centerline telescopic driveshafts that can’t be lost during heavy impacts, unlike dogbones. A simple, dependable, responsive steering assembly complements the ultra-reliable drive system and features a servo horn with built-in servo saver. The GRANITE™ 4X4 3S BLX RTR includes the waterproof Spektrum™ SPMS651 metal-geared digital servo for 15% more torque than the previous version’s ADS-7M servo.
The self-bleeding, oil-filled shocks, now with silicone O-rings, use a tried and tested, coil-over design for simple maintenance and amazing handling. Their innovative rod-end has a molded-in spring perch for extra toughness. Extended height dirt defenders and a close-fitting body limit the amount of dirt and debris that can get into the chassis tub. Front and rear bumpers offer defense against impacts.
Four dBoots® Fortress™ MT tires on gunmetal multi-spoke wheels give the GRANITE™ 4X4 3S BLX superb bite on a multitude of surfaces. ARRMA® has also installed a wheelie bar as standard. The aggressively styled truck body looks great while bashing and even better up-close and personal, with great attention to detail on the decal and body aesthetics. Choose green or red trim schemes.
Thread Tools |
I am so glad Arrma has upgraded this truck. I love my v1 Mega - upgraded to brushless - but I could not bring myself to recommend them to a new RC'er - because of the crap shocks and crap radio. With those two issues gone, this will be a killer truck, for newbs and experienced RC'ers alike.
My granite is fast, tough, handles great, jumps great, loads of fun. Probably my favorite truck in the garage right now. |
I just purchased one of these from my local Hobbytown. What a great looking truck! I haven’t had a chance to run it yet, but I love the updates that they have added (beefier wheelie bar, front bumper, etc.).
Looking for something to run in the grass with my dog, who is quite fast. ;-) |
If you run 3s, on road, it will get mid-40's till you start to lose stability - it can hit 50, but only with a good driver.
![]() On grass, it depends on what kind of grass (thick or thin) and how tall... For mowed park grass, the Granite goes good, but will max out around 25-35mph (depending on grass). Taller grass will make it go slower. If you really need it to outrun a 50lb dog that likes to run, in long grass, you need a 1/8 truggy with big MT tires. Look at the Arrma Kraton as an example. 60mph on road, and about 40-45mph on mowed park grass. Also, one of the 1/7 or 1/6 SCT like Losi Super Baja Rey or Arrma Mojave would work for high speed grass running. Full body will be safer if the dog catches the car, but will collect a lot of grass in the car. |
Thanks for the comments and suggestions. There is a pre-owned Kraton near by. May investigate.
Thread Tools | |
Similar Threads | |||||
News | ARRMA 1/5 KRATON 4X4 8S BLX Brushless Speed Monster Truck RTR | Jason Cole | Off-road Cars | 2 | Dec 11, 2019 09:36 PM |
News | 1/10 GRANITE MEGA 550 Brushed 4WD Monster Truck RTR (ARA102714T1) | Jim T. Graham | Off-road Cars | 0 | Aug 22, 2019 02:01 PM |
News | 1/10 OUTCAST 4x4 4S BLX Brushless Truggy RTR, Black (ARA102692) | Jim T. Graham | Off-road Cars | 9 | May 11, 2019 04:58 PM |
New Product | ARRMA 1/10 BIG ROCK CREW CAB 4x4 3S BLX Brushless RTR | Panhead5496 | Off-road Cars | 25 | Dec 04, 2018 05:11 AM |
News | 1/10 BIG ROCK CREW CAB 4x4 3S BLX Brushless RTR, Blue (ARA102711) | Jim T. Graham | Off-road Cars | 7 | Nov 20, 2018 04:50 PM |
