This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Sep 15, 2020, 10:43 PM
Mini-HowTo
Retaining the 4 Conscendo 3 mm wing bolts
The bolts fall out from there wing cover holes and are easily lost. I previously was rolling paper and glueing it inside the plastic tube. This worked until I assembled the wing but lost one of the bolts. Paper and glue work most of the time but I wanted something stronger that would last longer. I cut a slot in a 7/32 inch brass tube and then cut a 1/4 inch long section. The tube is a little loose in the tube but expanding the slot the tube fits snug in the plastic tube and a little Gorilla insures she stays in the tube. Donít forget to put the 3 mm wing bolt in the tube first. I cut down a 4 mm Phillips head bolt and had to reduce the diameter of the head because it was hard to fit into the tube.
Discussion Bolt or ? to attach outer panels 3 panel wing GoNavy The Builders Workshop 7 Jan 27, 2016 09:28 AM
Build Log "3/4-scale" MM clipped-wing Cub dk944s2 Parkflyers 19 Dec 02, 2008 08:46 PM
Question How to use retainer plug in Multiplex Multilock wing retainers? Giz Electric Sailplanes 2 Apr 24, 2007 10:18 AM
MM Hellcat Wing Bolt, What size is it.... SHOCKERS Parkflyers 5 Apr 23, 2005 09:57 PM
Graphite 3.1m full D-box (4 servo wing) versus Graphite 3.45m D-box (4 servo wing)? bfraser Electric Sailplanes 9 Jul 07, 2003 12:44 PM
