This thread is privately moderated by solarr, who may elect to delete unwanted replies.
Sep 15, 2020, 04:12 PM
Trader Rating: 76
$20.00 USD
Buyer pays shipping
For Sale
Eflite 30 Amp Pro Speed Control <<NEW LOWER PRICE>>
Price Reduced.
Eflite 30 Amp Pro speed control
Used but working perfectly.
Features
Up to 30A continuous current with proper airflow, with 35A peak
5V switch-mode BEC circuit capable of 700mAh continuous current on any recommended input voltage
Drives up to 5 analog or 4 digital sub-micro servos with the BEC
3S-4S Li-Po or 9- to 12-cell Ni-MH/Ni-Cd input voltage
Programmable motor braking
Safe power-arm mode prevents accidental starts
Programmable low voltage cut-off with settings for 3S Li-Po (9.2V), 4S Li-Po (12V) or 74% of battery starting voltage
Programmable soft start for helis and airplanes
Auto motor shutdown if signal is lost or there is interference
Programmable timing - 5 user selectable ranges for use with a larger variety of brushless motors
Heli mode for starting the motor with a low speed ratio
Optional RS232 Serial Link available for programming (EFLARS232)
Pre-wired connectors-E-flite EC3 connectors on battery input and 3.5mm female gold bullets on motor output leads
Specifications
Brake: Yes
Continuous Maximum Current: 30A
Input Voltage: 3S-4S Li-Po, 9- to 12-cell NiMH/NiCd input voltage
Input Connector Types: 16 AWG with E-flite EC3 Connector
Output Connector Types: 16 AWG with 3.5mm Female Gold Bullet Connectors
Momentary Peak Current: 35A
Dimensions (WxLxH): 28mm (1.1 in) x 51mm (2 in) x 8.7mm (.35in)
Weight: 31g (1.1 oz)
BEC Voltage: 700mA Continuous
Sold Eflite 30 Amp Pro Speed Control solarr Aircraft - Electric - Power Systems (FS/W) 2 Sep 09, 2020 12:26 PM
Sold Eflite 30 Amp Pro Speed Control solarr Aircraft - Electric - Power Systems (FS/W) 0 Aug 09, 2020 09:01 PM
Sold Parkzone 30 Amp Pro Speed Control solarr Aircraft - Electric - Power Systems (FS/W) 0 Jun 12, 2020 03:03 PM
Sold Eflite apprentice 30 amp speed control and brushless motor LTOB Aircraft - Electric - Power Systems (FS/W) 4 Sep 06, 2016 11:30 AM
For Sale 2 Eflite 30 amp sb pro speed controller rudyhal Aircraft - Electric - Power Systems (FS/W) 3 Apr 22, 2010 06:15 PM
