This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Sep 15, 2020, 07:18 AM
Video
Fun Cub 1100mm Wingspan EPO Kit - Aerobatic Flight & Aileron Adjustment Testing ;-)
Fun Cub 1100mm Wingspan EPO Trainer Airplane Kit
https://www.banggood.com/custlink/m3Gyp5QwBf
Banggood GCRC
https://www.banggood.com/custlink/GmDmQ1nVkO
Here is a link to the Fun Cub 1100mm Playlist:
https://www.youtube.com/playlist?lis...jUlSv6hkrevtUK
Here is a link to the Video:
https://www.youtube.com/watch?v=mOz2plUyYkg
Here are links to all the Components I picked out for this Kit Plane:
Racerstar BR2212 1400KV 2-4S Brushless Motor (Primary Motor)
https://www.banggood.com/Racerstar-B...47791920140372
APC 10x3 2-Blade Sport Composite Prop (BR2212 1400kv - Primary Prop)
https://www.apcprop.com/product/10x3/
APC 10x4 2-Blade Sport Composite Prop (BR2212 1400kv - Alternate Prop)
https://www.apcprop.com/product/10x4/
Racerstar BR2212 1800KV 2-4S Brushless Motor (Alternate #1 Motor)
JXF Poly Composite Propeller 8x4 (2pcs) (BR2212 1800kv - Primary Prop)
https://hobbyking.com/en_us/jxf-poly..._asc=897416588
Gemfan 8040 Propeller for RC Airplane Fixed-wing Aircraft 1 Pair (BR2212 1800kv - Alternate Prop)
https://www.banggood.com/Gemfan-8040...47791920140372
Racerstar Racing Edition 2216 BR2216 1400KV 2-4S Brushless Motor - Clockwise Screw Thread (Alternate #2 Motor)
https://www.banggood.com/Racerstar-R...47791920140372
TGS Precision Sport Propeller 9x3.8 (BR2216 1400kv - Primary Prop)
https://hobbyking.com/en_us/tgs-prec...asc=7285772039
ZOHD DART XL Extreme FPV RC Airplane Spare Part Propeller 9x4.5 Inch for Enhanced Version (BR2216 1400kv - Alternate Prop)
https://www.banggood.com/ZOHD-DART-X...47791920140372
Volantex Easy-Plug 30A 2-4S Brushless ESC With XT60 Plug (Primary)
https://www.banggood.com/Volantex-Ea...47791920140372
FMS Predator 40A Brushless ESC With 3A Switch BEC XT60 (Alternate)
https://www.banggood.com/FMS-Predato...47791920140372
CM703 2.4G 7CH RC Receiver With PPM Output (Alternate) (you need a receiver that supports your transmitter)
https://www.banggood.com/CM703-2_4G-...47791920140372
4X Racerstar DS1202MG 12g 180° Metal Gear Digital Micro Servo (Primary)
https://www.banggood.com/4PCS-Racers...47791920140372
4X SG90 Mini Micro Digital Servo 9g (Alternate)
https://www.banggood.com/4X-TowerPro...47791920140372
Gaoneng GNB 11.1V 1300mAh 3S 40C XT60 Plug Lipo
https://www.banggood.com/Gaoneng-GNB...47791920140372
You Can Help Support Us By Using Our Affiliate Links To The Products Above. A small commission (At No Cost To You) helps us buy more items to Test & Review.
#GroundControlRC #GlueAndFly #ScratchBuildPlanes #FunCub #FunCub1100mm #FunCub1100mmKit
#Banggood
See you in the Air!
Ground Control RC™ Glue & Fly™ Series Scratch-Build Planes
Consider Supporting Our Channel by becoming a Patron at: https://www.patreon.com/groundcontrolrc
Patrons of the Channel will have Exclusive access to Aircraft Plans & Content!
See Us On Youtube | Patreon | RCGroups
