This thread is privately moderated by MIKEYOUR, who may elect to delete unwanted replies.
Sep 14, 2020, 11:00 PM
Trader Rating: 399
"Thats right Iceman"
$35.00 USD
Seller Pays Shipping
For Sale
Multistar 350QX Blade Motor set 4pcs/Box 2209 1200KV 35$ shipped
set of 4 lightly used motors for your drone all work flawlessly
Free shipping
Looking for the ultimate power system for your next Multi-rotor project? Look no further!
The Turnigy Multistar outrunners are designed with one thing in mind - maximizing Multi-rotor performance! They feature high-end 42SH magnets, high quality bearings, High Pole counts for less noise, smooth responsive power and increased efficiency. They have custom motor mounting and all are precision balanced for smooth running. These motors are engineered specifically for multi-rotor use and are not based on airplane motors.
The 2209-1200KV MultiStar is almost too nice to fly! The workmanship and detail in this motor is at a whole new level. Itís fitted with shimmed and pre-loaded quality bearings and high grade silicon wires. It comes with three prop mounting options; A direct bolt T-style @ 12mm hole to hole spacing and 15mm hole to hole spacing for the Blade 350QX props, as well as a 3.17mm shaft for collet hub style propellers. The lower mounting plate has 14mm hole spacing and alignment pin holes with matching bullet connectors for a direct drop in replacement for the Blade 350QX Quadcopter. The 2209 is approximately a 100kv more than the stock 350QX motor at 1200kv, Perfect for aerobatics and punch out power or for the heaver camera gimbal equipped ones needing a little more power.
The new Multistar 2209 with its multiple propeller mounting options, increased performance and direct bolt in form factor makes this the perfect upgrade to the Blade 350QX or any other 350 class multirotor.
Multistar is simplifying the world of Multi-Rotors with their purpose built product line and taking the guess work out of your setup.
Specs:
KV(RPM/V): 1200
Lipo cells: 3s
Max Amps: 20A
Number of Poles: 12P14S (12poles 14 stators)
Dimensions(Dia.xL): 21 x 27.8mm
Motor Shaft: 3.17mm
For Sale Multistar 350QX Blade Motor set 4pcs/Box 2209 1200KV MIKEYOUR Aircraft - Electric - Multirotor (FS/W) 0 Apr 01, 2020 12:52 AM
Wanted Multistar 350qx 2209 motor fretman Aircraft - Electric - Multirotor (FS/W) 0 Nov 10, 2015 09:43 PM
Discussion Multistar 2209-1200KV and 2216-800KV Mr. UD Mini Multirotor Drones 0 Mar 23, 2015 05:02 AM
Sold Multistar 350QX Blade Motor Set Jerseydog Aircraft - Electric - Multirotor (FS/W) 0 Jun 06, 2014 08:22 PM
Sold 5 X multistar 2209 980kv new in box windfou Aircraft - Electric - Multirotor (FS/W) 1 Apr 24, 2014 04:06 PM
