Sep 14, 2020, 07:52 PM
ThomasLee's Avatar
New Product
KST X06 - 7mm servo
I'm very excited to show off the new X06 from KST. This has been in the works for around 3 years or so (with a break in between).
Full metal construction typical of KST, with a 7mm profile and around 6.5 grams, this is perfect for 1m models and for tails on some 1.5m models. If you're thinking of a 4-servo wing, this is it.
I've been benching testing the newest prototypes right before production and they're legit. Most of my comparisons were with the Blue Bird 101DMG since that has been my go-to 1m servo with similar size.
-Much stronger (around 50%) than the 101DMG
-Centering is much better than the 101DMG, but a little shy of the X08 v5
-Much less gear play than a 101DMG, but I think a fraction more than a X08 v5 (dual bearing) - I think I can notice it when I have both testing right beside each other
-Little bit slower, but not noticeable unless directly beside each other
-On paper it's taller than a 101DMG, but once horns are on it's actually around 1.5~2mm shorter
I'm installing 4 into a Deviant right now (build manual photos) and 2 into a Fury (tails).
I can't comment on reliability and use over time until I fly it for a few months, but brand-new performance so far has been very good on the bench.
Within the Deviant theme, I can see it easily being used for all 4 surfaces. 4 of these new servos will essentially be the same price as 2* X08 v5 and 2* 101DMG.
For 1.5m DLG it'll be good for stab, but I think rudder will need more testing to see how it handles the blowback on launch on 1S. For F5K it'll run perfectly on tails, much more power on 2S (HV capable). I think X08 will still be the de-facto choice for wings (F3K/F5K) and most likely rudder on F3K.
3.8V - 0.8 kg.cm
6.0V - 1.5 kg.cm
8.4V - 1.8 kg.cm
**Expecting our first batch in 10-14 days**
Sep 14, 2020, 08:00 PM
Launch high. Fly low.
Sep 14, 2020, 08:01 PM
need 'em
DUDE!!!
I need those ASAP. What happened to the 6mm servos?
When can I order?
Soar
Jun
Sep 14, 2020, 08:05 PM
ThomasLee's Avatar
These started out 6mm 3 years ago, we couldn't get the 6mm to work reliably enough. There simply aren't any available pots that can do what needs to be done at that dimension.
My first batch of 300 should be in my China warehouse by end of the month (www.armsoar.com), and I should have another 150 in the CA warehouse around Oct 10 or so (www.armsoarusa.com).
Have you thougt about running them on 2S for a 1.5mm DLG in the wings? Looks like you get comparable torque of a x08 on 1s.
Sep 14, 2020, 08:07 PM
ThomasLee's Avatar
I have, but I prefer to keep my DLGs on 1S. F5K on the other hand will usually be run 2S, so wings and tails can plug in directly. Will need to step down if using 3S powertrain.
Sep 14, 2020, 08:15 PM
ThomasLee's Avatar
I'm looking forward to Gavin testing these on the tails to see how well they hold up to launch on 1S. Might be enough? I doubt I would be able to strain them enough.
Sep 16, 2020, 12:47 PM
ThomasLee's Avatar
This is how it looks in a Deviant nose.
Sep 16, 2020, 08:34 PM
excellent. I think I will replace the bluebirds in my deviant (even though I don't have any problems with them now)
Sep 16, 2020, 11:10 PM
Zenoaheli's Avatar
if the servos are mounted in the fuse with a linkage, then why do they need to be so thin?
Yesterday, 04:30 AM
Rollo340's Avatar
They will also be used in DLG wings. I, for example might try a 4-servo F5K wing and definitely use the X06 for ailerons.
Rollo
Yesterday, 07:52 AM
eitanro's Avatar
Rollo
For a DLG? are you sure?
I would love to have them on my F5k to reduce quite a bit of weight...
Yesterday, 11:53 AM
Rollo340's Avatar
Yep, there are tendencies to a 4-servo wing in F3K and If it proves good, it would be the perfect aileron servo
Yesterday, 01:49 PM
eitanro's Avatar
I haven't seen that for more than 10 years... But even so, you need a beefier servo for the flaps unless the flaps are really tiny
Yesterday, 03:42 PM
Rollo340's Avatar
That’s why I wrote X06 for ailerons...X08 on Flaps
New Product New KST MS320 Digital, Metal Gears, Hi-Speed & Torque Servo hobbyclub Electric Heli Talk 26 Mar 12, 2019 10:06 AM
Discussion Replacing KST 215Mg servo gears akabek Electric Heli Talk 10 Dec 23, 2015 01:03 PM
Question KST DS515mg servos and a 500 Trex train06 Large Electric Helis 8 Dec 20, 2015 09:30 PM
Discussion d40 servos and KST servos wdeighton Dynamic Soaring 22 Jun 10, 2012 01:51 PM
