Link
surfTX (arduino_surface_TX_4ch)
[surfTX Github Page]
https://github.com/doohans/arduino_surface_TX_4ch This project is another fork from https://github.com/Gabapentin/Arduin...-Radio-control The focus of this project is Making PISTOL type TX for surface vehicle such as car or boat. |
This with free arduino pins and trims was more a question.
The only other thing I am mising is making the name only 4 leters, you cant input a space bar in the name. Regardles of this, this project is what I was shearching for a long time. Thanks for making this possible. ![]() ![]() |
Ar you asking about trim function? there is no Common Shared Trim function. only sub trim exist. but you can calibrate center position of pots(throttle, steering, ch3 and ch4).
calibration mode ; turn on power with pressing select button. And. do you need space letter for Model Name? if you do i will add space letter so that you can input the letter. |
2. In my case. i use underbar( _ ) instead of space ![]() for example "P929_". i will add space letter soon. plz wait. ![]() |
Now I only heave to make a front pannel for my transmitter, then I post some picts. |
Almost got it right...
Take 2!
Maybe i will cut names in the plate, for v3... |
SurfTx nRF24L01
Hi,
thank you in advance for the next modification TX of "Gabapentin". I transferred SurfTX to nRF24L01 and I2C LCD. I'm on 99% of CPU memory. The code will be optimized to include telemetry and possibly FHSS. I like direct control of RF SPI and open source. If you are interested, I will create a fork on Github. George ![]() |
I heave calibration problems, in 1.3 this was not the case. No more center as before..
When I upgradet it was working. Then I calibrated just for fun, and it is not centred any more. Tried erasing eprom, te result is the same. Will upload blank sketch when I heave time.
