Sep 11, 2020, 08:03 AM
Rotorhead
Resistance in all 4 motors
Hi!
I crashed my quad yesterday, all is working exept when i give throttle, all the motors turns very slow, like their braking, and i belive they only do about 30-40% of thrust with full throttle. And when the motors are not spinning i can truly feel the resistance with my hand and they wont spin freely at all if i just try to spin the propellers with my fingers.
So with no battery power, of course no resistance. With battery connected - no resistance. When i arm the quad without spin - no resistance. When i give throttle and idle down again it is resistance all the way until i unplug the battery.
All help and tips would be most appreciated.
Sorry for bad english.
Cheers,
André.
Sep 11, 2020, 02:44 PM
Check the screw at bottom.. maybe too tight.
Check if spinning freely.. could be rubbing. Very unlikely to happen to all.. thats more likely ESC issue.
Oct 22, 2020, 04:46 PM
Boaters are nice people.
Originally Posted by andytheman72
When I give throttle and idle down again it is resistance all the way until I unplug the battery.
Hi André,
Did you notice the resistance too before the crash?
Reason I ask, is I have something similar with my tri; when I'm done flying and (notice the difference to what you describe) unplug the battery, the motors still have magnetic resistance and don't spin freely.
It takes a while before this goes away. Does not affect the flying performance.
Do you notice any difference in flying characteristics, compared to before the crash?
Regards, Jan.
Oct 23, 2020, 05:20 PM
Your problem could be not enough demag or grounding issue. Try changing blheli timing and demag.
If a FET is broken/ shorted, motor will still spin, but get hot and have less power.
If winding is shorted you wiukd smell emanel burning in 2 sec.
Only other thing I can think of is the bearing.
My BH1504.5. Probably. Quad flies fine. Cant spin prop freely, but thats regardless if powered. ( not same as your case)
Discussion all in one 2.4 fpv system wanted scole FPV Equipment 4 Jun 02, 2016 06:06 PM
Discussion Smoked my motors. Replace all 4 or just the smoked ones? MaxPowers5 Mini Multirotor Drones 1 Dec 18, 2015 05:48 PM
Help! 1 of 4 Motors Spins with much less resistance when powered off. MarylandFly Multirotor Drone Electronics 0 Aug 02, 2014 10:34 AM
Discussion Cold Solder Joints/Resistance In Circuit: Hot Motors on Quad austntexan Multirotor Drone Electronics 2 Jun 30, 2013 06:20 PM
