May 13, 2005, 11:45 AM
Iron on heat shrink iron on covering
I have a plane that is covered in heat shrinking iron on covering, and parts of it are bubleing a little bit. The instructions said to buy a special heat shrinking material, but i don't have one. Can i use a regular iron and either turn the temp up or down? Please help!
May 13, 2005, 02:13 PM
(madkev :) )
kdwzagi's Avatar
heat shrink
hi
any iron will do, i use a small travelling iron for all my covering
slowly increase the heat untill you get the bubbles to go
my iron has settings for types of clothes
with it set on nylon it will tack the film down with very little shrinkage
half way between nylon and wool the covering shrinks a little
and with it just over wool it shrinks a lot
but if i go a little further past wool it starts to make the film look white (damaged)
make sure the under side of the iron is very smooth too or you may mark the wood under the film
all the best kev
ps here's one i did a couple of weeks ago
May 14, 2005, 08:42 PM
Maineiac63's Avatar
got a hair dryer ? Try that !
3/32" Heat Shrink Mod on my Hummer mdttb Micro Helis 7 Mar 11, 2004 03:40 PM
Iron on covering weights JimF Electric Ducted Fan Jet Talk 2 Mar 25, 2002 09:35 AM
GOT a Wedgie now whats THE BEST & lightest iron on covering for EPS FOAM rcracerx Foamies (Kits) 5 Feb 10, 2002 11:07 PM
Light Iron-on Covering pgleesonuk Sport Planes 19 Dec 24, 2001 05:40 AM
Iron on covering for slow flight RCFlybry Parkflyers 3 Dec 07, 2001 02:25 PM
