Jul 19, 2021, 10:20 PM
Never stop
Originally Posted by alb1661
is there a]external[ rf lite module that's available to sync with a spectrum receiver for my x20s
This is what you have to do: https://www.rcgroups.com/forums/show...postcount=8492
Jul 20, 2021, 12:30 AM
Hello
If you don't want to print an adapter. It can be bought on Bangood or Aliexpress.
Enzo
FrSky X20s / Ethos and Multiprotocol Module. No problem! (1 min 13 sec)
Jul 20, 2021, 02:52 AM
Originally Posted by AfterburnerRC
FRSKY better be sending a NEW Gimbal with the correct mounting hole, that is unacceptable as mine does not have this and I have the X20S version.
$51.99 https://www.horusrc.com/en/frsky-tan...mbal-mc11.html
Jul 20, 2021, 04:55 AM
K10Steve's Avatar
Telemetry Issue
Had my first flights with the X20 yesterday using 1.0.10 RC4. This was a Radian glider with S6R RX, flown many times previously with my X10 Express. No changes were made to the RX installation. Had 3 flights, no control issues but suffered problems on the telemetry side with many altitude spikes on the first 2 flights then altitude continually reported as -237 feet on the 3rd. RX is on v2.1.0 EU LBT. Log file example below.
Jul 20, 2021, 06:19 AM
Looks like RC 10.5 has been withdrawn.
Jul 20, 2021, 07:26 AM
Jet_Flyer's Avatar
Yes there was an issue if negative percentage numbers were used in the Mixer like negative differential.
RC6 is here https://github.com/FrSkyRC/ETHOS-Fee....10-candidate6
Jul 20, 2021, 08:05 AM
Originally Posted by mawz
Interesting, because sticks & switches was the default set on my X20.
Perhaps they changed it?
I removed the radio.bin file, flashed to RC6, did the calibration and the only thing that wakes the display by default is 'keys'. Not the sticks, switches or gyro. I actually rather it this way but just want the trims to work without having to wake anything up.
Jul 20, 2021, 08:11 AM
Sagitta Fanboy
I'm still on 1.0.9, sounds like 1.0.10 changes the default for that, or at least the current RC does.
Jul 20, 2021, 08:58 AM
aerografixs's Avatar
I mentioned earlier just go and change it ,
Jul 20, 2021, 09:22 AM
Thank You for your reply
left_drift,v.eight and mawz
Jul 20, 2021, 09:23 AM
It's not clear to me what you are saying. As far as I can tell, you can't have the screen dim to save battery and have the trims work without having to wake it.
Jul 20, 2021, 09:47 AM
Jet_Flyer's Avatar
If you check you will find that all the keys work the same in sleep. You could open an issue on GitHub to see if there is a way to take the trims out of the awake process or some other solution. GitHub https://github.com/FrSkyRC/ETHOS-Fee...mmunity/issues
Jul 20, 2021, 10:50 AM
check here
Jul 20, 2021, 11:01 AM
need a lil help here.
just completed a delta mix (dont know why there isnt a preprogrammed mix)
mixer looks like my screen shot here.
problem is that the trims work on only 1 surface at a time.
so if i use the trims on ailerons only 1 servo moves.
the free mix servo does not move with the trim position.
any guesses on what im doing wrong.
thanks in advance.
cheers
Jul 20, 2021, 11:21 AM
I'm glad you understand what I was trying to say! I'll open a request in GitHub! Thank you sir!
New Product Frsky Horus X11 and Tandem receivers skorp_jon Radios 165 Apr 13, 2021 10:45 PM
New Product New Syma X20 Review Bill M - RC Micro Multirotor Drones 0 May 05, 2017 01:16 PM
News New! Ares Ethos QX 130 Jason Cole Multirotor Drone Talk 654 Sep 16, 2016 02:28 PM
Discussion New owner of a Ares ETHOS QX75 (I THINK??) Waterbound Mini Multirotor Drones 7 Apr 04, 2014 01:32 PM
