Sep 19, 2020, 09:53 AM
perttime's Avatar
Neck strap is a matter of taste. I like to have one to steady the transmitter a bit and ensure I don't drop it while hand launching.
Actually, I think the one I've been using was originally meant as a strap for a company badge or keys or something....
Sep 19, 2020, 12:44 PM
thanks, i have one of those! i'll try it first.
Sep 19, 2020, 03:17 PM
The first cut is the deepest
Sep 19, 2020, 03:34 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Off to a good start !
Sep 19, 2020, 04:22 PM
corners are very slightly bunged from shipment, does that matter?
Sep 19, 2020, 04:27 PM
dihedral is vague if the wings were upside down, how many inches from the surface to the joint?
how to glue the wings, they don't meet in a flush fit. bead of glue down the top of the joint?
Sep 19, 2020, 05:07 PM
corners are very slightly bunnged from shipment, does that matter?
how to gkle the wings, they don't meet in a flush fit. bead of glue down the top of the joint?
You are building a disposable plane , the chances are it's going to get a lot more bungged !
Dihedral angle doesn't have to be exact , just copy what you see in the photo below as best you can .
Sep 19, 2020, 05:13 PM
Yes , you can put a couple of pieces of masking tape on the top , then stand the wings up on the tail end with some dihedral angle . Then run a bead of glue down the "V" gap on the bottom side .
The goal is "flyable" , not "perfection" . Any mistakes made are lessons learned .
Sep 19, 2020, 06:24 PM
will do!
Sep 19, 2020, 06:51 PM
will do!
Keep posting pictures , I'd love to see your progress !
Sep 19, 2020, 06:58 PM
it's going to be slow for now, too nice out to be in the basement
Sep 20, 2020, 06:37 PM
Second cut, I donít see a picture of the fuselage attachment to the wings?
Sep 20, 2020, 07:01 PM
Are the wings glued together with dihedral ? If so , turn the wings over ( upside down ) on a table ..... then glue the fuselage to the wings so the fuselage is as close to 90ļ to the table ( straight up ) as possible . It's OK to eyeball it . After the glue has set , glue some strips of foam board where the fuselage and wings are joined ..... like a fillet weld . That will strengthen the joint between the wings and fuselage .
Sep 20, 2020, 07:06 PM
nothing glued yet. should i do the wings first?
Sep 20, 2020, 07:34 PM
Yes sir .
Article What Are You Building this Winter? Jason Cole Electric Plane Talk 399 Oct 20, 2020 02:05 PM
Question What Are You Building This Winter? mdickey Sailplane Talk 160 Jun 10, 2020 08:05 PM
Help! newbie wants to build a lightweight quad, parts help thesculptor Beginner Multirotor Drones 16 Jul 20, 2018 04:17 PM
Build Log This winter's build: the Sig Four Star 40 ralphnumbers Balsa Builders 17 Nov 16, 2016 09:43 PM
Discussion Newbie wants to build Slow Easy Foamie MSE63 Foamies (Scratchbuilt) 17 May 18, 2008 08:41 AM
