Sep 09, 2020, 06:56 PM
Originally Posted by balsa or carbon
Walmart has inexpensive cutting mats and low temp glue guns in the crafts department , can be ordered online and shipped .
https://www.walmart.com/ip/24-x-36-G...g-Mat/39752313
https://www.walmart.com/ip/AdTech-Mi...Pack/147699873
https://www.walmart.com/ip/AdTech-Cr...ticks/17404370
funny, i ordered the glue gun from walmart, and received it from amazon
Sep 09, 2020, 07:00 PM
Sometimes they put it in the title "M2" .
i see one that says 'model_2', fs-i6 with fs-ia6 receiver, $51., arrives 9-17
in the description, it says: please note, mode 1, throttle stick on right, mode 2, throttle stick on left
Sep 09, 2020, 07:25 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
I grabbed the screenshot from this Amazon page :
https://www.amazon.com/FlySky-FS-i6-...697163&sr=8-33
If you are used to flying with the throttle on the left stick on your transmitters , then be sure to order a "mode 2" transmitter .
Sep 09, 2020, 07:33 PM
looks good! will it work with the other electronics you recommemded? should i order it?
Sep 09, 2020, 08:23 PM
Yes , the electronics from Value Hobby will work with a FlySky FSi6 transmitter .
For the most peace of mind : If there is a way to contact the Amazon seller and make sure that the transmitter is mode 2 , then I would do that .
The identical Turnigy i6 I linked in post #29 is definitely mode 2 , it says so clearly on the page :
https://hobbyking.com/en_us/turnigy-..._2_group_0_asc
Sep 09, 2020, 11:27 PM
Laughs at un-boxing videos...
basicguy's Avatar
Be careful about anything from Valuehobby.
If you have a problem you are going to have to eat it. I am still waiting on return authorization now for almost 3 years for a $300 item. Even the Chinese are better than them when it comes to returns.
Just doing my share in spreading the joy about VH.
Check out the words under my handle.
When you look at a transmitter go with a 6 channel. Be sure to check out the price of their receivers. Some brands suck you in with decent priced transmitter and roll you with high priced receivers. I have a big investment in flysky equipment and generally found it to be a good value. A basic airplane can have two aileron, servos a motor channel, elevator and rudder.
Sep 10, 2020, 09:13 AM
treefinder
springer's Avatar
What basic said. I was going to comment on that as well. While I used a single aileron servo on my earlier planes (4 channels: aileron, elevator, throttle, rudder) as I got building larger planes, the logistics of connecting the fuse mounted (or center of wing mounted) ail servo got increasingly complicated. It quickly got easier to just use a servo on each wing. I could have used a wye and tied the the two into the ail channel, but learned about adverse yaw which could resolve by programming aileron differential into the two ail channels. ( so 5 channels used: ail, ele, the, rud, ail). Yes, I could have achieved some differential mechanically, but it was more "fun" doing it with mixes in the TX. Said all that to support purchase of the 6 ch FS-i6.
Sep 10, 2020, 11:08 AM
thanks all!
question, will the glue gun work on my cracked in half volantex sport 500 epp foam wing?
Sep 10, 2020, 11:11 AM
treefinder
springer's Avatar
yes, although Welders is probably better for EPP. Get it it home depot, I think.
Sep 10, 2020, 01:11 PM
thank you!
Sep 17, 2020, 10:16 AM
cutting board arrived, new blade in the razor knife, time to try my hand at foam cutting!
Sep 17, 2020, 10:59 AM
If you're learning to fly, get a simulator! Then you can practice all winter and be ready for 'real' flying come spring!
Regarding choice of transmitter I'm super happy with a Walkera Devo 10 flashed with DeviationTX. Dsm2/x compatible, fully programmable and cheap.
Sep 17, 2020, 01:08 PM
thanks! does anything work with a macbook?
Sep 17, 2020, 03:16 PM
https://apps.apple.com/us/app/aerofl...94308605?mt=12
If you get a Spektrum transmitter , you can connect wirelessly with this dongle :
https://www.horizonhobby.com/product...11980001548780
Sep 17, 2020, 03:18 PM
Let us know how it goes !
Article What Are You Building this Winter? Jason Cole Electric Plane Talk 399 Oct 20, 2020 02:05 PM
Question What Are You Building This Winter? mdickey Sailplane Talk 160 Jun 10, 2020 08:05 PM
Help! newbie wants to build a lightweight quad, parts help thesculptor Beginner Multirotor Drones 16 Jul 20, 2018 04:17 PM
Build Log This winter's build: the Sig Four Star 40 ralphnumbers Balsa Builders 17 Nov 16, 2016 09:43 PM
Discussion Newbie wants to build Slow Easy Foamie MSE63 Foamies (Scratchbuilt) 17 May 18, 2008 08:41 AM
