Looking really good.
Burn Out!
The majority of this model has been framed up and ready for final sanding. However, I am approaching "burn out" on this build . I need to take a break and work on something else that is not so challenging for a while.
Like Arnold Schwarzenegger said, "I'll be back". -Vic |
Wow! Sorry I missed all this Vic. But, as I said in my PM, I have not been modelling much the last few years.
You DO seem to have more refined plans that mine were. And I did not have any laser cut parts, I hand cut each one! That job really sucked, but every so often... By the way, most of those pics you found in the magazine article are actually of my build! I provided them to the guy that wrote the article. I never even got a copy of that mag as it is not available here! I think when all is done and you maiden the plane, you'll be amazed at how docile and forgiving it is. I know I had serious misgivings about the Frise ailerons, but they work the same as any other aileron in practise. And that landing gear is amazing at absorbing the bumps of a grass field. Chris |
Chris, thanks for the info and flying tips. I will not install the big flap - too much work for unnecessary scale detail. As for flying, I have heard it flies like a box kite so I will not fly it unless it is a calm day. After modifying the lower wing into a 3-piece wing, I am going to keep the upper wing in one piece although it will be cumbersome to transport.
Thanks again for the info. -Vic |
Motor Cooling
Yet another "scratch-your-head" situation in the model design. I was just looking over the engine nacelles and cowling and notice that there is a large hole in the nose block to serve as a cooling air inlet. However, I do not see any way for the air to get out, therefore the "flow of cooling air is essentially blocked" once the cowl is installed.
Can someone tell me the flowpath for "cooling air flow" ? Please don't tell me sufficient cooling is provided by the turbulent air inside the cowl during flight. -Vic |
Vic,
I've just spent some time looking at prototype photos, and it seems that turbulent air in the cowl may well be the strategy. In all seriousness, it looks as if the upper cowl sits a bit above the wing and provides a gap for air to escape that is visible in the images below. There are also numerous other gaps, such as around the exhaust, and a fair amount of space around the wheel. I don't know what the structure looks like inside the nacelle, so not all of those areas may actually exit hot air. https://live.staticflickr.com/3865/1...525e13fb_b.jpg https://cdn.airplane-pictures.net/im...27/1149697.jpg |
Reason: added second image link
Great photos, and a good exit for cooling air. But what's going on at the TE just outboard of the struts?
-Vic Update: I have been informed that the thicker section of the bottom wing is to accommodate fuel tanks. |
I may just leave off the cowl rear cover (purple) from the cowl to the top of the wing. It is just a cosmetic addition on the model. -Vic NOTE: The planned scale-like flying style for this model will not require full power from the motors, so they may not overheat with good throttle management. |
I have another plane on the way. It may push the DH90 off the work bench to allow work to proceed on the new project. The DH90 has presented many challenges which have started to become a PITA. I have to force myself to work on it every day I come to my shop. There is a lot more work required to finish this model and my interest to finish it is diminishing.
-Vic |
I'm very sorry to hear that Vic. Yes, put it aside for a while then finish it in a flash!
I understand your frustration with the DH90. The plans leave a lot of things to the builders discretion which was typical before CAD drawing and advances in technology for building model aircraft. I think taking a break is a good course of action and has been said when you come back to it things should move right along. I'll be looking forward to watching your completion of the build. For me, the DH90 build has taken considerably more time than I thought it would. I have only built a few models and have learned from each of them and this one has definitely given me some new insight and building skills. I will post my progress this weekend. Take care. John |
Thread Tools | |
Similar Threads | |||||
Discussion | Vic's Custom Model Scorpion | SeismicCWave | Classic Pattern Flying | 39 | Oct 26, 2020 03:08 PM |
Build Log | DH90 Dragonfly after-build | eye4wings | Scale Kit/Scratch Built | 581 | Oct 02, 2020 10:34 AM |
Build Log | DH90 Dragonfly from Ivan Pettigrew's plans | nickchud | Scale Kit/Scratch Built | 92 | Sep 07, 2020 03:06 PM |
Build Log | 50+ Build-Off -- Vic Smeed's 'Mamselle' 1.7X | cpmcgraw | Vintage & Old-Timer Designs | 51 | Aug 12, 2016 01:57 AM |
Cool | Vic and Vic's Garage Sale | AceMigKiller | Arizona Model Aviators | 58 | Jun 11, 2012 09:13 PM |
