This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Sep 02, 2020, 06:50 PM
old4570's Avatar
P1B-1 ( Still a big Northerly blowing )
Product link
Hmmmm , watch the assembly video by JHA if this interests you .
https://www.youtube.com/watch?reload...ature=emb_logo
I would not in hind sight tape the plastic fittings on ( foam protection tabs ) .. I did it in the tail as in the JHA video , but immediately regretted it ! Just glue them in place .
With the wing I glued the carbon spar in place ( Foam safe cyno ) also gluing the two wing halves together . The plastic protector ( protects the foam from the rubber band ) was glued in place with HK Foam Glue . Also the carbon tail boom was glued into the plastic locator as well the vertical stab .
Assembly is relatively simple once you know what needs doing ( instructions are not even good toilet paper ) . If you are going to let children do the assembly , I would strongly suggest following the JHA Video .
Mine is assembled and ready for play . Though the million dollar question is when do I get to play with it ? ..
RTF , mine came in at some 30.5 grams . ( With rubber motor )
Rubber motor , = I cut the supplied rubber in half , tied the ends and then folded it two and inserted it inside the tube .
I have tested it and the motor system seems to work fine ..
I would have liked lighter propeller blades . , but it is what it is .
Next comes flying when ever that is ?
Sep 02, 2020, 06:57 PM
Hey, watch this!
Raymond-leflyr's Avatar
I saw a Youtube video on adding an R/C rudder to one of these. I haven't started on doing that to mine but I'm hopeful that I can keep it in our park flyer field and maybe even land it withing walking distance.
Sep 02, 2020, 07:05 PM
old4570's Avatar
JHA has some interesting video on the P1B-1
And there is a RC conversion on Youtube ( was it only rudder ? ) , will need to watch it I think .
FF is a very interesting discipline . It's where I started long ago . Chucky / Towline / then CO2 and then C/L as a teen .
Discussion LAPD blows it big time. RCWorks Life, The Universe, and Politics 34 Aug 08, 2018 03:10 PM
Discussion Will my BEC still work if I blow my ESC? Jumpin Joe Power Systems 3 May 17, 2011 02:50 AM
Discussion PSS English-Electric Lightning P1b/F1 Phil.Taylor Slope 23 Jul 31, 2008 02:11 PM
1.22V / cell Nimh, very small 11A load on a big CC125, but still shutting down... Protocooler Castle Creations 11 Dec 01, 2005 12:17 PM
