Aug 28, 2020, 11:15 AM
Registered RC NUT!
The Snake's Avatar
Alert
Freewing 80mm JAS-39 Gripen
Pre-Order / Reservation Details - Please read this information carefully before ordering:
This is the pre-order for the Freewing JAS-39 Gripen 80mm EDF Jet - PNP.
The current expected arrival date is late October 2020. Any changes to the ETA will be posted on this page.
JAS 39 Gripen 80mm EDF Jet - PNP from Freewing - FJ21811P
The JAS 39 Gripen’s unique delta wing and canard configuration endows it with excellent agility, most notably a tighter turning radius than the American F-16! Flown by more than a dozen NATO countries, the Gripen is a Mach 2 multi-role fighter whose 25 year service history continues onward with distinction.
Freewing has raised the bar again for RC foam electric delta winged jets with the JAS 39 Gripen. This jet is precisely modeled for scale fidelity and practical RC performance, and assembles in minutes including pre-installed electronics and LED lighting. Powered by our popular 80mm 9-blade Inrunner EDF and a 100A ESC, the Freewing Gripen is designed for power! At ~1/9 scale and 1613mm/63” in length, the Freewing Gripen is longer than its predecessor, the Freewing Typhoon/Eurofighter. Referencing the full size Gripen’s short take-off capabilities, the Freewing Gripen is optimized for short take-offs and surviving unkempt landing strips.
Recommended for intermediate to advanced skill level pilots, the Freewing Gripen offers the power, size and speed of a 90mm super scale jet, in a lighter, faster, and more economical 80mm EDF Series package. Full-functioning canards enable high agility, and full-coverage gear doors improve the airframe’s overall aerodynamics.
Visit the Official Freewing JAS 39 Gripen 80mm EDF Jet thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
Impressive Size
Measuring over 63” long, the Freewing Gripen delivers powerhouse performance in a field-friendly size. A 12” removable nosecone makes transportation a breeze!
High Scale Fidelity
Fly the world’s first electric Gripen with all the “bells and whistles” of larger EDF class sizes. Lights, suspensions struts, full-coverage gear doors, and optional upgrade paths!
Full Function Canards
A rarity in the RC EDF Jet world, full function canards give you full command of the Freewing Gripen’s exhilarating flight envelope in both pitch and roll!
Pre-Installed LED Lighting
The Freewing Gripen features pre-installed DayBright LED Lighting out-of-the-box, using red and green position lights and a bright white landing light.
LED Lighting
Inrunner Power!
Achieve top speeds above 170kph/105mph with our popular and powerful 1920kv brushless Inrunner power system and 9 blade reinforced EDF unit!
Grass-Ready Retracts
Durable aluminum suspension struts are concealed by full-coverage landing gear doors for optimal aerodynamics. All-new specially designed trailing link main struts soak up rough runways with ease.
A Century of Service
True-to-life “Heritage” markings commemorate the Czech Air Force’s 100th Anniversary, having fought from 1918-2018 alongside the Allies from World War 2 to various NATO Coalition conflicts to the present day.
Honor the past to preserve the future!
Upgradeable
Optional 3DPUP (“3D Printed Upgrade Part”) Sets, sold separately, will be made available in late 2020. These sets include a 360 degree 3DTV Thrust Vectoring Nozzle Set that pilots can install themselves using basic hobby skills.
FEATURES:
Full Function canard operation
9-blade EDF with 3658-1920kV Inrunner brushless motor for incredible efficiency and performance surpassing 170kph/105mph top speed
Full-coverage landing gear doors for optimized aerodynamics
Durable metal landing gear for operation on grass and gravel runways
Preinstalled ball linkage and decals
63” total length
12” long removable magnetic nose cone for easy transportation
True-To-Life livery commemorating the 100th Anniversary of Allied and NATO service of the Czech Air Force
INCLUDES:
Freewing JAS 39 Gripen 80mm EDF Jet - PNP
Brushless motor, servos and ESC preinstalled
Instruction manual
REQUIRES:
7 Channel radio
7 Channel receiver
6 Cell 22.2V 4000-6000 mAh LiPo battery with EC5 connector
6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
PRODUCT SPECIFICATIONS:
AGE LEVEL : 14 AND UP SKILL LEVEL : INTERMEDIATE BUILD TIME : 1 HOUR
Model Scale
1/9 Scale
Wingspan
882mm /35in
Length
1613mm / 63in
Weight
2350g / 83oz (w/o battery)
CG (Center of Gravity)
Molded Into Fuselage (130mm aft of canard root)
Power System
6S 3658-1920kV Inrunner Motor (included)
Electronic Speed Control
100A with 5A UBEC (included)
Propeller / EDF
80mm 9-Blade EDF (included)
Servos
9g hybrid digital standard with 200mm lead : left aileron, right aileron
9g hybrid digital standard with 300mm lead : nose gear steering
9g hybrid digital metal gear standard with 600mm lead : left canard, right canard
9g hybrid digital standard with 1050mm lead : rudder
Landing Gear
Electronic retractable aluminum trailing link (included)
Required Battery
6S 22.2V 4000-6000mAh LiPo with EC5 Connector (required)
Required Radio
6+ Channel (required)
Ailerons
Yes
Elevator
Yes
Rudder
Yes
Canards
Yes
Lights
Yes
Hinge Type
Nylon Reinforced
Material
EPO Foam
Skill Level
Intermediate
Build Time
1 Hour
Recommended Environment
Outdoors
Canard Mixing of the Freewing 80mm JAS-39 Gripen - Motion RC EDF RC Jet (18 min 17 sec)
CG and Rates for the Freewing JAS-39 Gripen - Motion RC EDF RC Jet (14 min 18 sec)
Futaba Canard Mix Setup - Freewing 80mm JAS-39 Gripen - Motion RC EDF RC Jet (14 min 2 sec)
https://www.motionrc.com/collections...mm-edf-jet-pnp
https://www.motionrc.com/collections...mm-edf-jet-arp
https://www.motionrc.com/products/fr...escription-tab
more details coming!
Aug 28, 2020, 01:30 PM
Great...
Thanks.
Love the Gripen more than the Rafale :-)
Hope the size fit to my Mid size Car.
Oh no ... length Is 63 inches. Hope the Nose
Is Removable to fit the mid size car...
Yes. the nose is 12 inches and Removable
for Car..
YYYYY ... EEEEE.... SSSSSSSSS...
Thanks FREEWING :-)
.l
Aug 28, 2020, 01:36 PM
Flying R/C since 1964
kallend's Avatar
Originally Posted by flylow2011
Great...
Thanks.
Thanks FREEWING :-)
.l
Post #1 stated:
63” total length
12” long removable magnetic nose cone for easy transportation.
Ordered mine.
Mine mine mine (Finding Nemo) (0 min 32 sec)
Aug 28, 2020, 01:37 PM
Great...
Thanks.
Thanks FREEWING :-)
.l
Yes, the nose comes off! Looks like a very nice model. It will be interesting how it will compete with the FMS Rafale.
Aug 28, 2020, 02:09 PM
FREEWING uses
100th anniversary scheme of Czech Gripen is
nice and Visible tooo....
Good bye Rafale for now. :-)
Aug 28, 2020, 03:00 PM
edwen303's Avatar
This Gripen is slightly shorter than Mig-21 with larger wingspan, just a little heavier than 21. Would be interesting to see how she performs and handles
Aug 28, 2020, 03:16 PM
flanker271's Avatar
I had a feeling it'll roll like crazy with the amount of recommended aileron & canard throws at high rate in the manual. I had to dial it way down for the Mirage.
Aug 28, 2020, 03:42 PM
Flying Hazard
SU-4ever's Avatar
Aaaand... I'm in for this one too!
Aug 28, 2020, 03:56 PM
Wonder why need 7 channels?
1/ throttle
2/ Rudder
3/ landing gears
4/ ailevons 2 servos 2 channels
5/ canards ...
So only 6 channels...
Aug 28, 2020, 04:21 PM
1/ throttle
2/ Rudder
3/ landing gears
5/ canards ...
Canards maybe need 2 ch?
Aug 28, 2020, 04:24 PM
flanker271's Avatar
Canards function as elevons, so each need its own channel.
Aug 28, 2020, 04:31 PM
kallend's Avatar
1/ throttle
2/ Rudder
3/ landing gears
5/ canards ...
There's "need" and there's "what I want".
Mine will have 8, and all will be put to good use.
Aug 28, 2020, 04:45 PM
11, i want
Aug 28, 2020, 04:47 PM
I know what you have in mind SIR... :-)
Thrust vectoring with SAFE , Stabilizer :-) so
you can do flat spin and All kinds of maneuvers
BTW seems you have Spektrum Dx8 gen 2?
I wonder should I upgrade to DX 8 or DX9 ?
Build Log Aerotetris JAS-39 Gripen (2-seater) Mankan Foamy EDFs 120 Dec 12, 2020 12:04 PM
Build Log Jas 39 Gripen 1/10 evolve Scratchbuilt EDFs 44 Nov 16, 2020 02:14 AM
Video Maiden on ​Skymaster JAS-39 Gripen BjarneKvilvang Jet Turbines 5 Jul 17, 2018 04:06 PM
Discussion SAAB Gripen JAS-39 A/C salata73 Scale Kit/Scratch Built 2 Oct 26, 2017 07:58 AM
JAS-39 Gripen section drawing. rcaviator Electric Ducted Fan Jet Talk 1 Feb 21, 2003 02:10 PM
