Aug 19, 2020, 05:12 PM
nano output voltage
if i input 8.4volts into a nano, what would the output be?
i am setting up a small glider and servos are rated ,at most, at 6v. i probably need regulator but I thought i'd ask.
ron
Aug 19, 2020, 09:28 PM
Build more, websurf less
FlyingW's Avatar
Ron,
The servos will get the full 8.4 volts. A main hobbies have a small lightweight 2-cell 500mah Life rx pack at about 6 volts that might work for you.
Good luck,
Paul
Aug 20, 2020, 01:11 AM
None of our products regulate the voltage, so whatever you put in is what the servos get.
Aug 20, 2020, 09:00 PM
thanks paul and jim. ron
Help! Dps 1200FB no voltage output after floating it MicroRasus Batteries and Chargers 6 Apr 02, 2017 12:52 PM
Discussion Different voltages between main output and balance ports Crashanium Batteries and Chargers 2 Mar 26, 2016 12:58 PM
Discussion Output Voltage is Higher Than The Selected Cells kopijun Batteries and Chargers 3 Mar 14, 2016 12:17 PM
Discussion Ts5823 vtx output voltage? greenlight149 FPV Talk 0 Nov 25, 2015 03:41 AM
Discussion How does DC input voltage relate to 3phase output voltage? AluminumRCdude Power Systems 8 Apr 25, 2014 12:33 PM
