Aug 19, 2020, 03:45 AM
30C or 50C batteries for a 60A ESC in an Eflite Carbon Cub Z SS 2.1m
I have a new Eflite Carbon Cub Z SS 2.1m BNF which comes with a 60A ESC. I want to know if it would be better to purchase a 30C batery or a 50C battery. What would be the differences / limitations?
Aug 19, 2020, 08:58 AM
Tzicul's Avatar
Considering the size of your airplane, I suppose you will need at least 4-5.000 mAh battery. At this size, 30C should be enough (you will have between 120 and 150A - in theory). However, bigger is better, right?
Sent from my H8216 using Tapatalk
Aug 19, 2020, 09:22 AM
You may also need to consider weight, in particular with reference to CoG, and size.
Also, it may or may not be important to you, but I believe a higher C rate might also mean you can charge at a higher rate, thus charge quicker. Check out before purchasing.
Aug 19, 2020, 06:51 PM
Perpetual Noob
BoxCar31's Avatar
A C rating is a multiplier of the battery capacity meaning it can provide the C rating times the capacity in short bursts. So, a 30C 5000ma battery can supply 150 Amps of current to the ESC in short bursts. You need to keep in mind that almost all C ratings are pie-in-the-sky theoretical values and the actual amount of burst current is always less than what the label implies. Battery life is partially a factor on how much current is pulled from the battery over time so lower demands usually equates to longer life. Pulling 60 Amps from a 5000ma battery is only a 12C demand.
Aug 22, 2020, 02:47 PM
C rating is marketing for most battery companies.
Aug 22, 2020, 02:54 PM
Fly 'm if you got 'm
MrEFlyer's Avatar
Go with the recommendations you got in the other thread with your same question.
New Product The NEW E-flite Carbon-Z Cub SS 2.1m ...Better Than Ever Giant-Scale Experience! Jason M Electric Plane Talk 1722 Jul 25, 2021 02:27 PM
Help! Lighting for eflite 2.1 Carbon Cub ss dmohring Electric Plane Talk 1 Jul 02, 2020 10:08 PM
Help! Disregard...11x7 Carbon Z Cub SS 2.1m Props Masterguns Power Systems 1 May 26, 2020 12:02 PM
