Aug 18, 2020, 09:29 PM
Aerofoam L-39 review
So beginning of this year I converted a freewing l39 to turbine it was fun but wanted something bigger as an everyday jet. So I picked up the aerofoam L-39 from global jet club along with an acex 80. First off it showed up in like a day im not sure how you even ship a jet that fast ! When I pull it out of the box I see that it has aluminum control arms and ball links and this jet is built very well I slap it together and spray it with minwax. The "build" takes about 3 hrs and im ready . I take it out and the first flight I drag it in for probably the slowest turbine landing I have seen. Im 8hrs into the turbine and 50 flights of some hard flying and no signs of stress on the wings this thing is a tank I even got my buddy into turbines buddy boxing on this jet. Short and sweet if you want a first turbine/trainer buy this jet . If you want a cheap fun sport jet buy this jet. If your on a budget for a turbine jet buy this jet!!! Right at 3k rtf I promise it going to fly better then any 2500 dollar deal on a beat up twin boom used I can't say enough about how much fun this jet is. I can't thank the global jet club team enough for all there help and support thank you Carrie and Ralph
Aug 19, 2020, 06:01 AM
How well does the minwax work?
Aug 19, 2020, 07:17 AM
did you have any issues with main gear doors coming open during flight ?
Aug 19, 2020, 09:49 AM
wannabe Jet guy
CRCJA's Avatar
Glad you are having fun with it. I even did one with a 45n Turbine installed. Here is a video from Las Vegas
Ralph
Aerofoam L39 with small turbine (3 min 8 sec)
Aug 19, 2020, 01:23 PM
The doors do sag a little im going to put a small spring in there to see if it helps and the minwax is nice it gives it a nice flat covering that dosnt stain with dirty hands
Aug 19, 2020, 02:28 PM
Thanks I removed my doors for now . It is a great flyer, enjoying mine. I need to find a place to source some small springs
Aug 19, 2020, 08:51 PM
@cableguy351 do you have an ace hardware near you?
Aug 20, 2020, 07:11 AM
not close but there is one . Do they have the springs ?
Aug 22, 2020, 12:29 AM
Yes they normally have a great set up
Aug 23, 2020, 08:28 AM
wannabe Jet guy
CRCJA's Avatar
I forgot that when I received the last L-39, I made an unboxing video. Well I finally uploaded. Enjoy.
Aerofoam L-39 Unboxing (9 min 9 sec)
Aug 23, 2020, 01:52 PM
Battery Puffer
Hi Ralph
I ordered one of these as edf. Can you tell me the diameter at the end of the tail pipe? I want to know my maximum size my exhaust tube can be. Do you think a jetfan 110 would be a good fit?
Aug 23, 2020, 03:07 PM
I just received the same jet it will be my first turbine. I am amazed at the quality of the plane. The foam is very very hard. I would love to see more pictures of your minwax job. Will it crack/yellow in the sun?
Aug 23, 2020, 03:37 PM
Youtube: TomRi25
Dr.Tom's Avatar
Any videos for us to enjoy?
How would it hold up on grass ?
How big are wheels (inch/mm)?
I have kingtech k80g2 which is a bit heavy, 8.6kg thrust, but do hope CG would be ok, and not too hot for landing.
Turbine is 1300grams, how much does your
acex80 weight? I see batteries are full in front already for cg.
Aug 24, 2020, 10:47 PM
The mains are 65mm
I think it would do fine on cut grass
The motor sits on the CG so a little more weight would be fine
Aug 25, 2020, 05:21 AM
Youtube: TomRi25
Dr.Tom's Avatar
Thanks for the wheels info, they seem up to the job, just would like more grass op videos before buying.
Can you tell me what is spacing between the turbine mounts inside the plane.
Hope 11.5cm or more.
About weight,
So the whole 1.6L(kg) of fuel is in front of cg?
New Product Global AeroFoam L-39 CRCJA Jet Turbines 149 Nov 23, 2021 03:04 AM
Discussion 1800mm Aerofoam (105mm or Turbine) L-39 demetrius Foamy EDFs 9 Jun 21, 2021 11:09 PM
