This thread is privately moderated by wingloada, who may elect to delete unwanted replies.
Aug 18, 2020, 08:04 PM
wingloada's Avatar
New CNC Foam cutter
Well...
It's been many years since I posted here. All said, things are fine and I hope to be here a bit more often than in the past few years. I hope you are all doing OK during these tough times.
My current project is building a CNC hot wire foam cutter based on rckeith's plans and instructions. I've wanted one of these since Kevin Sharbonda showed me his hand-built CNC cutter many years ago when I picked up the wing cores for my eSupra. I've now completed the build, run through the calibrating and testing and now I can cut very precise foam cores of all sizes. I have been testing the machine and software on very small wing panels just to see what the accuracy can be without using a lot of foam materials. The cutter is controlled by rckeith's GRBL HotWire Mega 5X for CNC Foam Cutters Windows application.
Here are a few videos of the cutter at work.
One
Two
Three
Aug 22, 2020, 12:48 AM
Great build Bill looks like you've got the hang of it. Thanks for the credits.
Keith
Discussion Simple but mighty DIY 4 axis CNC Foam Cutter - Theremino Controller (Not Arduino)! pieri70 CAD/CAM 152 Jul 01, 2020 07:20 AM
Build Log CNC Hot wire foam cutter jhraley CAD/CAM 12 Dec 16, 2016 09:38 PM
Discussion How I cut a wing foam core with my CNC foam cutter wzg_zxl The Builders Workshop 21 Nov 27, 2016 02:20 PM
Discussion Cnc foam cutter program info JMDESIGNS CAD/CAM 10 Jan 30, 2016 07:23 AM
Cool my new cnc foam cutter and cnc milling machine logicalmetal Foamy EDFs 6 Sep 15, 2010 03:46 AM
