Aug 13, 2020, 12:33 PM
New AR630 6ch AS3X receiver
I see that the new AR630 6-channel Spektrum AS3X receiver has been announced -
Programs like an AR637T, you can use a SRXL2 remote RX with it, and the main RX has the integrated antenna similar to the AF620 and AR410.
Looks good, I may have to pick one up for a scratch built foamie that's been laying on my bench for some time. Plan to use separate aileron servos with it so I can experiment with flaps / or coupled flaps/elevator like a control line stunt plane just for the heck of it.
Bet with the case off it's not very heavy at all - it's only 9.5 grams according to the specs, and the case is probably 1/3 to 1/2 that..
Aug 13, 2020, 12:46 PM
Fully Sending It
Xpress..'s Avatar
Looks like a solid unit with a good price point to utilize all of the forward programming capabilities.
https://www.spektrumrc.com/Products/...rodID=SPMAR630
Aug 13, 2020, 01:10 PM
richard hanson's Avatar
For those who care---
all these new rx will work as basic rx perfectly well with no programming
worth doing ?
yes
they have advanced sensitivity design
Better for less-------------------
Aug 13, 2020, 03:10 PM
Pro Bro # 2398
GassPasser's Avatar
looks good to me..
Aug 13, 2020, 03:31 PM
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
Nice!
I have a couple of AR620ís and bought an AR410 for an upcoming project. Great things coming from Spektrum.
Latest blog entry: RC Throw Gauge
Aug 14, 2020, 06:48 PM
Bagpipes spoken here
Pipemajor's Avatar
I was curious why the AR637T was released with the dipole antennae. Makes installing into smaller airframes a bit more complex and this new 6ch RX is $30 less!
Also anxiously awaiting a 8+ch of one of these.
Aug 16, 2020, 09:00 AM
Ian Kunz's Avatar
I’m going to put one in my GWS Corsair that I’m just finishing up. Been using a 620 for setup but want one of these in it.
Aug 16, 2020, 11:05 AM
These new improved sensitivity rx bare really great but some buyers think that the long whiskers improve operation
Actually , what they do. Is move the point of reception
Thats it
If you have an all foam model for example, where the rx can be located easily,to allow clear signal view, no whiskers needed
Properly Locating the whisker tips is usually easier ,especially if rx location is cramped but
Whiskers or no whiskers, these new rx have better reception
You just have to locate the end of the rx or the whisker tips where incoming mail can be seen
Aug 17, 2020, 07:45 PM
I like the no antenna design, however has no connectors for flight pack voltage, XBus, will probably will stick with my AR637T's for now. Looks like an update for the AR636B receiver...
I think they now have the 6 channel receiver line well covered. Wish they would work on the 8 to 9 channel line...
Aug 18, 2020, 09:00 AM
Is this just for foamies/parkfliers? Short range? From the description I don’t see whether it’s full or short range
Aug 18, 2020, 09:01 AM
Originally Posted by quietfly
Is this just for foamies/parkfliers? Short range? From the description I donít see whether itís full or short range
Full range. (Telemetry is short range)
Aug 18, 2020, 10:55 AM
Thanks.
Aug 18, 2020, 11:09 AM
You may findthe telemetry is also longer
Aug 20, 2020, 05:44 PM
Fire Marshall Bill
TPorter
+1!! They put out a 20 ch Tx and only 6 ch Rxs??? Don't need 20 but 7-9 would be nice!
Aug 21, 2020, 06:19 AM
eihoward's Avatar
All foam planes use 6 or less channels, and they sell a lot of them... its a priority for them to replace the 6 channel AR636 first.
Discussion New AS3X Receivers AR9350, AR7350, AR636 and AR6335 WITH INTEGRATED TELEMETRY ! Mukenukem Radios 12497 Oct 23, 2020 09:29 AM
Discussion Spektrum AR630 is Coming - SAFE+FP+Antennaless mawz Radios 13 Mar 31, 2020 01:08 AM
Discussion Can I use an external ESC(10amp) with a AS6410NBL DSMX 6Ch AS3X Receiver? acesshex Scratchbuilt Indoor and Micro Models 12 Jan 04, 2015 02:34 AM
Help! New RedCon 6ch 2.4ghz receiver runaway G Bond Electric Plane Talk 5 Jul 31, 2011 07:36 PM
