Rob FPV Stealth 360 InVisible Drone Frame
If you are into 360 video and want a drone frame that can go invisible to the footage, then this made in the USA frame from Bob-FPV is what you are seeking.
Great Price on a Cool Frame for 360 Videos
If you are into 360 video and want a drone frame that can go invisible to the footage, then this made in the USA frame from Bob-FPV is what you are seeking. Key details are it's on sale for $65 as a pre-sale and you can get it in 4-7 days from placing your order.
It works with the Insta360 One R or the GoPro Max. He built the frame thin enough to fit inside the blind spots of the camera lenses so the drone itself becomes invisible and you are left 360 degrees of clean video to work with and edit.
Stealth 360 frame kit comes with:
  • 2mm top plate
  • 2mm bottom plate
  • 4 arms with Motor Bolt Pattern: M2 (12X12mm)
  • All the hardware you need to build the frame.
  • TPU FPV Camera holder
  • You can purchase our custom 360 camera hinge or download the file and 3d print yourself. (link provided once the frame is purchased)
Features:
  • Be invisible
  • Can use the stock camera holder
  • Stay invisible with Insta360 One R and Go Pro Max
  • Diverse build configurations
  • Changeable arms
  • DJI/Caddx Vista and Nebula capable.
  • Use any thin lipos up to 6s with DJI
  • AIO, 20x20, 30x30, mounting holes.
  • Fits up to 6" props (5" t-prop recommend to stay invisible)
Recommended parts list (NOT INCLUDED):
  • Motors: Brother Hobby 2004 1950kv
  • Props: HQ Durable T5x2.5x3 or Gemfan Hurricane SL 5125-3
  • FC/ESC : 20x20 Diatone MambaF722 Mini DJI F35 or JHEMCU GHF405 35 amp Whoop style board
  • Battery: CNHL Minster 450mah 6s
  • FPV System
Check out the Stealth 360 InVisible Drone Frame Here
Sep 01, 2020, 01:36 AM
thanks for sharing
Discussion Hoverthings Flip 360 FPV Frame Vantasstic Multirotor Drone Talk 2632 Dec 13, 2015 07:30 PM
Discussion Hoverthings Flip 360 Frame - FPV Video Example FPVAus Multirotor Drone Talk 0 Feb 16, 2014 04:58 AM
Discussion stealth drone from the movie STEALTH. built from scratch. crispy1074 Scratchbuilt EDFs 5 Sep 25, 2012 08:15 PM
Discussion stealth drone from the movie STEALTH. built from scratch. crispy1074 Foamy EDFs 7 Sep 21, 2012 02:01 PM
