Carbon Repair Kits by CCM
As pretty and nice as modern F5J planes are, it's pretty rare for them to remain in pristine shape. Between hangar rash, rough landings, obstacles and midairs, there are plenty of ways to damage your carbon and foam core wings or fuselage.
Be Prepared with a Repair Kit
As pretty and nice as modern F5J planes are, it's pretty rare for them to remain in pristine shape. Between hangar rash, rough landings, obstacles and midairs, there are plenty of ways to damage your carbon and foam core wings or fuselage. Having it happen at a contest is the worst and unless you have a backup plane ready, you'll need to be prepared to fix it. Having a small supply of repair materials on hand is important and can really save the day when needed.
FlightComp is offering a repair kit made by CCM and it's certainly worthy of keeping with you for when the inevitable happens. This kit will allow you to make a quick field repair and get your bird back in the air. All you'd need is something to cut with and some CA or epoxy to finish the job. The kit includes a nice selection of carbon and rohacell foam. Check out the full contents in the list below. The kit sells for just $34.99 which seems like a great deal.
Composite Model Repair Kit V2:
  • Carbon Dbox for patching or covering up leading edge damage. Aprox- 170mm x 70mm
  • 1 piece of 100 grit sand paper
  • 3 piece of Spread Tow carbon ST20, 175mm x 215mm
  • 1 Piece of Spread Tow carbon ST40, 175mm x 215mm
  • 1 Piece of light weight rohacell foam, 135mm x 195mm x 7mm
  • 1 Piece of light weight rohacell foam, 70mm x120mm x 19mm
Check out the Carbon Repair Kit at FlightComp
Aug 13, 2020, 07:35 AM
turn, turn, turn.
Kenny Sharp's Avatar
Cool thanks. Just ordered version 2.
Build Log CCM Hypnosis double carbon winchdoc Slope 109 Jul 19, 2020 10:48 PM
New Product Vuhlets Carbon Fiber Repair Kits wdwimbish Hand Launch 42 Dec 05, 2019 10:47 AM
News Glider Repair Lab DVD by Radio Carbon Art Jim T. Graham Sailplane Talk 16 Dec 13, 2014 06:21 PM
Help! How repair carbon boom? Broke at v-tail joint so can't wrap with carbon tow.... 4444 The Builders Workshop 9 Jul 09, 2006 05:54 PM
e-Scorpion 2 60" by CCM guillaume83 Electric Sailplanes 32 May 07, 2005 01:50 PM
