Vintage Steering
I've been working on a totally scratch-built tug for the last several months. This tug is a compilation of ideas I've gleaned from pictures, searches, and "if it looks right, it works for me." Although this isn't a build log, I thought someone may be interested in the steering system, and a couple of shots of the progress.
The steering concept isn't new for sure because several old steam tugs used chains to pull over the rudder quadrants through a steam engine mounted either behind the deck house, or in the aft end of the engine room. I didn't have the correct angle or space for a quadrant, but was able to use a yoke. The problem to over come with a yoke is the chains had to track straight fore and aft across the deck like a quadrant would allow. As the yoke turned the angle of the chains decreased dragging them across the deck side to side. The answer here was to install a couple of fairlead wheels aft of the rudder post then turn the chains around them creating a straight consistent track across the deck to the servo mounted in the engine room. There's another winter's work in this build with the interior details, doors, windows, and deck gear, but it has been launched, and run several times. All ballasted and in running trim she weighs 47 lbs. She's 55 inches long, and 1:18 scale. ImagesView all Images in thread
Thank you Pat.
This seemed like a worthwhile experiment. The biggest concern was the strength of the chain in the correct scale. None of the costume jewelry chains of the required size had the tensile strength needed. I ended up getting a couple meters of stainless steel chain from Germany. SS Master tug in the Vancouver (a lot of video on her on Youtube, ) has steam/chain steering which lets the chains out of the bulwarks aft around a turning block then run forward and back aboard in the area of the deckhouse aft. Seguin had chain boxes across her aft deck. |
Thread Tools | |
Similar Threads | |||||
Help! | HELP!! Steering flopping and steering not returning to original position | Scornado | Electric Power Cars | 3 | Dec 31, 2018 08:41 PM |
Discussion | Steering Modes: 2WS, 4WS, & Crab Steering | Buzz_Man | Robotics | 5 | Jul 29, 2018 10:18 AM |
Help! | Quesiton Prop torq steering and prop walk | wdac | Racing Boats - Electric | 5 | Oct 21, 2015 09:15 AM |
Discussion | Getting That Straight Line Steering - issue. | maneyecool | Electric Power Cars | 7 | Oct 14, 2015 02:30 AM |
Cool | Vintage "remote control" cam steering device | Kmot | Dock Talk | 6 | Apr 05, 2011 12:10 AM |
