Gator RC - New Seagull Models!!!
We have expanded the Seagull Models by a dozen! All models are available for pre-order. Orders will ship out to you in the next five to six weeks. Please let us know if there are any questions.
Supermarine Spitfire, Battle of Britain (ARF), (Limited Edition) Flat finish
  • Wingspan 86.4in
  • Wing are 1325.3sq.in
  • Approximate flying weight 17.6-18.1lbs
  • Length 72in
  • Recommended engine size 50cc-55cc
Click here for more info.
T-6A Texan II, USAF Trainer (ARF)
  • Wingspan 63.0 in
  • Wing area 648.0 sq.in
  • Approximate flying weight 9.3 lbs
  • Length 58 in
  • Recommended engine size 75-.91 2-Stroke / .91-1.00 4-Stroke/Electric Equivalent
Savage Shock Cub, Yellow/Black, 35-55cc (ARF)
  • 35cc-50cc gasoline engine.
  • Wingspan 102 inches
  • Recommended engine size 35cc-50cc
  • ELECTRIC CONVERSION INCLUDED
Savage Shock Cub, Silver/Black, 35-50cc
  • Radio system required 6 channels with 8 servos
  • Flying skill level intermediate/advanced
  • ITEM CODE: SEA357
Decathlon 120, Red, 79" (ARF)
  • Wingspan: 78.7 in (200 cm)
  • Wing Area: 1032.8 sp.in (66.6 dm˛)
  • Weight: 10.6 lbs (4.8 kg)
  • Length: 52.9 in (134.4 cm)
  • Engine/Motor size: .91 2-stroke, 1.20 4 Stroke or 15cc-20cc Gas
  • Servo: 6 channels 6 servos
  • ITEM CODE : SEA83
For more info click here.
Christen Eagle (ARF)
The classic aerobatic bipe alternative has never been more lovingly rendered than in Seagull’s meticulously crafted, Oracovered and laser-cut masterpiece. The sinuous curves are captured perfectly with crisp elegance, even the laser-cut fuselage stringers are scalloped between bulkheads for better strength/lighter weight. Choice and selection of materials is exemplary too as is the slippery aerobatic profile of the beautifully finished balsa wings with their strong aluminium tube wing joiners, sheeted D box leading edge and painstakingly applied Oracovertrim colour scheme. Like all Seagull cowlings, this is beautifully made from light weight glass cloth, spray painted and finishedas always, with a crystal clear fuel-proof lacquer.
Cessna 152, 80" (ARF)
  • Wingspan: 80 in (203 cm)
  • Wing Area: 911.4 sp.in (58.8 dm˛)
  • Weight: 9.9 lbs (4.5 kg)
  • Length: 57.5 in (146 cm)
  • Engine/Motor size: .75-.91 2-stroke, 1.20 4 Stroke or 15cc-20cc Gas
  • Servo: 5 channels 8 servos
  • ITEM CODE : SEA174
Steen Skybolt, 15CC
  • Wingspan: 61″ / 155 cm
  • Wing Area: 1023 sq in / 66 sq.dm
  • Length: 48.2 in / 122.4 cm
  • Flying Weight: 9.3 lbs / 4.2 kg
  • Engine/Motor: 2-stroke .90 or gasoline 15 cc, or electric equivalent
  • Electric Conversion Kit Included
  • Requires 6 Channel Radio, 6 Servos
  • Assembly Time: 10-15 Hours
GeeBee 120
  • Wingspan: 70.9″ / 180 cm
  • Wing Area: 863.4 sq in / 55.7 sq.dm
  • Length: 46.6 in / 118.3 cm
  • Flying Weight: 10.6 lbs / 4.8 kg
  • Engine/Motor: 2-stroke 1.2, 4-stroke 1.5 or gasoline 20cc, or electric equivalent
  • Requires 4-6 Channel Radio, 6 Servos
Aug 18, 2020, 05:43 PM
Same Day Delivery
mike3976's Avatar
Where is the .60 size Kaos ARF, I don't see it !!!
Aug 28, 2020, 08:05 PM
ltc
ltc
AMA 97737
ltc's Avatar
Wait, what?
Where did you hear about that?
Discussion Gator RC's new 81" Spitfire sumobob Electric Warbirds 14 Aug 08, 2020 02:49 PM
Discussion Seagull models seagull models steen skybolt n250sb 15cc – sea237b nemesis4u Product Announcements 0 Aug 03, 2020 02:55 AM
Article Gator-RC - Super Tucano 91, Seagull Models Jim T. Graham Scale Fuel Planes 3 Apr 09, 2020 06:00 PM
Article Gator-RC - Seagull Models Skyraider - 15cc Jim T. Graham Scale Fuel Planes 0 Apr 03, 2020 06:34 AM
New Product Cloud Nine Model 1055mm Seagull RC Seaplane!! Whitehouse Electric Plane Talk 3 Jun 10, 2017 07:07 PM
