Aug 08, 2020, 03:58 AM
1 can never have 2 many planes
chambo88's Avatar
Build Log
Yakovlev mini Yak 3 600mm (3D Aeroworks) LW-edition
On the back of the success of the mini LW-PLA spitfire, ive decided to start a mini series of models for those calm mornings at the park/flying field.
and so the second of the LW series is the Yak 3.
started design this evening and will be basing the design using the same concepts as the spitfire.
specs
4 channel (AILERON, ELEVATOR, RUDDER AND THROTTLE)
950mah 2s
1806 2300kv on a scale prop 5x4.75 3 blade
3.7g servos
RTF weight : 278g
files available here:
https://cults3d.com/en/3d-model/vari...m-3d_aeroworks
flight video:
Yakovlev Yak-3 600mm (2 min 7 sec)
Aug 08, 2020, 11:15 PM
Airplane nerd
i know that I am new here but if you need reference photos I have access to this specific plane , as well as the yak 9 ( which is what i believe your plane is if im not mistaken) a yak 3 , yak 52, yak 18 .and a T6 Texan.
Aug 09, 2020, 06:05 AM
chambo88's Avatar
Thanks for the offer. I am using war thunder as a reference for each model which gives me highly detailed 3d models I can rotate and adjust the view.. I appreciate the offer but I beleive I should be fine for now. If you are interested, I will be looking for test pilots when the first version is ready
Aug 09, 2020, 12:22 PM
Airplane nerd
Absolutely. Not to mention the guy that owns the yaks would love a model of one. On a second question. Do you think you could do a yak 52?
Aug 12, 2020, 06:35 PM
chambo88's Avatar
Sure thing i can do a 52. I'll be doing a wide range of 600mm models from all regions and era's. Best thing about the smaller models if I keep them at the same span is the overall structural support layout can generally remain the same which will drastically cut down on design and testing time as well as maintaining the same electrical setup.
Aug 15, 2020, 04:26 PM
chambo88's Avatar
got the modelling finished last night and cut up. Need to slice then it'll be ready to print!
this will be a little heavier than the spit as the scale size makes the fuse slightly larger than the spitfire. also added a little extra support to the fuse around the canopy cut out. estimating RTFW of about 220-230g
the prototype will be suited for larger printers with a high print volume. once tested ill make it suitable for 200x200x200 printers.
Aug 17, 2020, 08:48 PM
Airplane nerd
This is awesome. Id be interested in a couple yak 52s . Non flyable. They would be static models for a couple friends that have full scale 52's
Aug 17, 2020, 09:14 PM
chambo88's Avatar
Sounds good. Would they need to have moveable control surfaces?? Also how big? On a stand, or mounted?
Aug 18, 2020, 09:13 PM
nsr500v
1100mm 1200MM ??
Great ww2 fighter that i would like to see in 1100mm and 1200m also please
Aug 19, 2020, 08:23 AM
Airplane nerd
Actually the size would be the same as the other planes. There going to hang in the hanger
Aug 24, 2020, 06:35 AM
chambo88's Avatar
Printed out and will be ready for a maiden flight this weekend. Just gotta fit servos and pushrods.
Can't wait!!
Aug 24, 2020, 10:07 AM
nsr500v
Can't wait!!
that looks sweet . A+
Aug 25, 2020, 03:10 AM
Good luck to you this coming weekend!
When and where can I download the files chambo 88 ?
Greetings:Robin
Aug 25, 2020, 05:13 AM
chambo88's Avatar
Files will be available after the maiden flight. will post a link.
Aug 27, 2020, 09:26 AM
chambo88's Avatar
managed to get a decent chunk of time this evening and managed to get this bird ready for the air!
balanced and RTFW is 250g.. not bad for 600mm.
got the scale 3 blade prop done as well.. replaceable blades with a single m2 screw. the spinner winds on to the thread of the motor for a clean looking finish. Definitely needed for the balance. See how it goes, it balances on the conservative side i like to use for the maiden with a 950mah 2s, but ill take a little lead just in case it goes the same way as the spitfire.
just need to tune the receiver and trim control surfaces but i should be able to maiden it 2moro.
stay tuned! fingers crossed. .
Build Log Mk IX mini Spitfire 600mm (3D Aeroworks) LW-edition chambo88 3D Printed Planes 298 Yesterday 05:03 PM
Discussion Avios Yakovlev Yak-52 1100mm DutchRC Electric Warbirds 6 Oct 18, 2015 03:00 PM
Discussion Yakovlev Yak-52 TedD60 Scale Drawings and Three Views 4 Sep 20, 2015 08:48 AM
Contest Scale Build-Off 3 - 46" Yakovlev Yak-11 Chad Veich Scale Kit/Scratch Built 49 May 28, 2014 12:30 AM
Gallery Yakovlev Yak-3 davidterrell80 Scale Drawings and Three Views 1 Feb 25, 2014 09:20 AM
