DJI built the RoboMaster EP Core specifically for STEM education. This is one of the most advanced educational robots available that can offer beginner and advanced level programming projects for students of all ages. The RoboMaster EP Core is a solid vehicle made from steel and has some amazing hardware to go with it along with room to expand. Check out some of the features listed below.
The EP Core’s Robotic Arm is incredibly durable, yet compact and flexible. It supports precise FPV control, allowing students to complete tasks even when the target objects are out of sight.
The Gripper transforms the EP Core into a powerful robot with multiple functions. A convenient structural design and adjustable gripping force empower it to firmly and reliably grasp and move objects of various shapes, weights, and sizes.
The EP Core comes with four Mecanum wheels, each with 12 rollers that allow omnidirectional movement and precision control. Front axis suspension allows for added versatility during operation.
As a propulsion driver for the EP Core, the servo supports customized control abilities through the EP Core’s main control board. It ensures high control accuracy and large output torque. It can also power the Robotic Arm and allow students to build lifting structures using their knowledge of physics.
Each sensor adaptor has two ports and provides power supply. A power connector module can connect and power third-party hardware, offering multiple ports to connect hardware and create custom programs and applications.
Using a powerful CPU, the Intelligent Controller can simultaneously support functions such as low-latency high-definition image transmission, AI computing, and programming development. It also coordinates transmission seamlessly to execute command signals.
With a measurement range of 0.1-10 meters, the infrared distance sensor provides reliable distance measurement information. This enables the EP Core to sense its environment and avoid obstacles, deepening students’ understanding of advanced autonomous driving principles.
The EP Core comes with a customized motor that features an integrated FOC ESC with an output torque of up to 250 mN•m. Linear Hall-effect sensors with advanced algorithms allow closed-loop control for added precision. Additional safety mechanisms deliver outstanding stability.
The versatility to accommodate third-party hardware such as building blocks and 3D printed objects provides unlimited options for learning and unlocks students’ potential and imagination.
The RoboMaster EP Core supports third-party open-source hardware such as Micro:bit, Arduino, and Raspberry Pi. These items can be connected and powered via serial ports on the main controller of the chassis. The EP Core can also perform model training and scene recognition through AI platforms such as NVIDIA Jetson Nano and the official DJI SDK, enhancing students’ understandings of the operating principles of AI.
The RoboMaster EP Core is equipped with four sensor adaptors, making it convenient to connect and power third-party sensors that measure inputs such as temperature, pressure, distance, and more. Sensory data can even be used in Scratch, unlocking endless programming possibilities.
So if you can't tell already, this is a powerful educational product with amazing possibilities. The next generation of coders and tech engineers are going to have a blast learning on the RoboMaster EP Core.
Introducing the RoboMaster EP Core (3 min 27 sec) |
Thread Tools |
Not sure. They are having people send in a contact form for purchase inquiries at the moment.
Thread Tools | |
Similar Threads | |||||
New Product | DJI Robomaster S1 STEAM DIY 4WD Brushless HD FPV APP Control Intelligent Educational | Merch | Banggood.com | 2 | Sep 07, 2019 02:44 PM |
Discussion | DJI Tello with 5MP HD Camera 720P WiFi FPV 8D Flips Bounce Mode STEM Coding Compatibl | scousethief | Banggood.com | 0 | Jan 08, 2018 12:43 PM |
