Jul 28, 2020, 11:17 PM
Radjet 120 Mph
I dropped my radio and now I have a problem
While putting my planes together I dropped my Spektrum DX9 TX from about 4 feet. My flap switch came loose but everything else looked fine. Until I tried my first flight. Of the day when I move the ailerons left or right and relax the sticks the ailerons do not return to neutral and the plane keeps rolling . You can force the aileron by pushing the opposite direction. Makes for a interesting flight experience. This is a problem only with the ailerons on the TX. I connected 3 other airplanes and all had the same problem. Before I tear into this TX does anyone have any idea what to look for? how to test the gimbal and where I can get parts if needed.
Thanks Bob
Last edited by Biker66; Jul 31, 2020 at 11:09 AM. Reason: More accurate discription
Jul 29, 2020, 12:24 AM
Radjet 120 Mph
And just to clarify It only happens in one direction. Ailiron to the right and return to center, Ailiron to the left and it stays left when I release the stick.
Jul 29, 2020, 07:00 AM
Perpetual Noob
BoxCar31's Avatar
Send it in for repair.
Jul 29, 2020, 08:29 AM
Change title to “ I dropped my radio and now I have a problem.”
Send it in for repair, the sooner you do the quicker it will be repaired!
Jul 29, 2020, 10:49 AM
Radjet 120 Mph
OK Thanks everyone, that's what ill do
Jul 29, 2020, 12:37 PM
TX abuse.
Jul 29, 2020, 01:48 PM
speed2004's Avatar
I saw what you did there Quietfly.
Jul 31, 2020, 11:08 AM
Radjet 120 Mph
I bought a new DX9 to keep flying but am thinking about replacing the gimbals on my defective unit with the FrSky M9 Hal Gimbals.
Jul 31, 2020, 11:37 AM
William A's Avatar
Sounds like it's physically broken. Like a spring or spring attachment point.
Open it up and look. Mechanically they're pretty simple.
Edit; The manual has pics and steps to split the case.
Aug 01, 2020, 07:00 AM
Next time consider buying a radio that you can buy parts for. Then you can fix it yourself.
Aug 01, 2020, 07:05 PM
Zeeb's Avatar
Messing around with a radio transmitting device, without the appropriate licenses, testing equipment and certification, is illegal in the USA.....
Aug 01, 2020, 09:31 PM
I think you are mistaken. Have you never replaced a transmitter battery or antenna?
You may not mess with the RF output circuitry, but you may change other parts like switches, gimbals, batteries, antenna, even the case.
There are manufacturers that make all commonly damaged parts available to the public for replacement in the event of damage. And at very attractive prices I might add.
Aug 01, 2020, 09:40 PM
Sagitta Fanboy
Spektrum/Horizon support is good enough that this is a non-issue. They'll fix just about anything for the cost of shipping.
It can be a real issue for some other brands, and not necessarily the ones you expect (good luck getting Graupner service in the USA right now)
Aug 01, 2020, 09:43 PM
Sagitta Fanboy
With modern systems, that's only an issue if you are messing with the RF module or an antenna mod. You can do pretty much anything you want to the rest of the radio and remain legal.
Older FM/PCM radios definitely required the licenses and certification if they were manually tuneable (some of the late designs used fully solid state RF modules).
PS, even then a HAM Technician license is sufficient as long as you work on your own equipment.
Aug 01, 2020, 10:15 PM
koppterX's Avatar
Echo just send it in but I wouldn’t expect gratis repair for obvious damage. But they will go through it too.
Discussion URGENT Spektrum DX9 Firware Update Problems RickSkid Radios 30 Jun 06, 2018 08:55 AM
Discussion Spektrum DX9 Problems/Rant lycokayaker Radios 19 Apr 11, 2016 04:48 PM
Help! Problem setting mixes in DX9 Jack_K Radios 17 Dec 08, 2015 08:49 PM
Discussion Spektrum DX9 Problem Updating Sound Files rocket_33 Radios 41 Oct 25, 2015 12:29 PM
Question DX9 Spektrum registration problem Jan Sig Radios 1 Sep 30, 2013 08:43 AM
