Oct 29, 2020, 05:17 PM
W. X. Davis's Avatar
THX guys.
Hey Hans. How're things across the pond ? Hope things are fine with you and yours.
Size wasn't really the issue as much as I was concerned more with the shape. Today was spent shaping, reshaping, cutting out and replacing then shaping the added portions. Using 3 view plans and reference books, I think I've finally got it. There will be some minor tweeking then on to making the plug.
I'm ready to move on to a different portion of the build. Might get back to working on the tail.
Oct 29, 2020, 05:29 PM
I think the pink project foam turned out much better than the depron version. There's really no comparison.
Woody
Oct 30, 2020, 04:40 PM
After getting the canopy shape right ( I think ) I moved on to getting it ready to make the plug. The first step is to fill little divets and cracks. Next step was to glass the foam. This is necessary 'cuz I use auto body finishing putty ( two part ) which will eat the foam if applied directly to it. I can usually get it on in one application but this canopy is rather large and you only have so much time to get it on before it starts to set. It took three separate sessions to cover the mold. It's kinda' like icing a cake except with a running clock.
As mentioned I'm gonna try and add the frame to the plug. I've done this before with reasonable success. With the putty applied it will dry over night to allow it to completely set. After that it will be time for rigorous sanding.
Oct 30, 2020, 08:29 PM
Zipman's Avatar
Those earlier canopy plugs came out great. The buckeye should also. What kind of tape do you use for the frame?
Do you have to put a coat of sealer over the tape?
Oct 30, 2020, 10:05 PM
Hey Zipman...................if I remember correctly I used masking tape stacked 3 deep. I don't recall using a sealer.
Woody
Oct 30, 2020, 10:12 PM
Zipman's Avatar
Thanks, I was wondering how thick it was. It would be the easiest to apply and shape.
Oct 31, 2020, 07:44 AM
Again, it's been awhile since those canopies so the method is a little foggy. I used the wide tape (3 deep ) on a thick glass sheet on which I'd cut. I would draw the frame on the plug cut the patterns from paper then transfer that to the tape, cut out then apply.
Oct 31, 2020, 03:57 PM
i12flyrc's Avatar
I've used trim stripe tape before and that seems to work as well.
Oct 31, 2020, 06:21 PM
Hey Mike. Something like chart pak tape ?
I've been using the wide masking tape which is large enough to cut out patterns if necessary.
Woody
Nov 01, 2020, 02:45 PM
i12flyrc's Avatar
Woody
Yep, chart pak works well.
Nov 03, 2020, 01:26 AM
No pics to show. Spent the day filling pinholes and imperfections to the canopy and fuselage. The canopy has been wet sanded and the frame is being drawn in. Hopefully I can start applying the tape frame.
The more I fill and blend on the fuselage the more issues I find. It might take another day or so to finish it up. Then I can start glassing.
Woody
Nov 03, 2020, 07:12 PM
After smoothing the plug surface it was time to apply the frame. This is a process 'cuz it requires the frame be drawn onto the plug , traced then drawn on the layered tape then applied to the plug. I have a 18" square 1/4 thick piece of tempered glass that I lay the tape to then cut with a #11 xacto knife. This was an all day affair. But if done right it really enhances the model.
In the next day or so I'll build the tub to hold the mold making material to pour the plug. I'll have to get in the right frame of mind because once you start you have to go from making the mold, then pouring the plug, so everything has to be ready to go. The reason for the haste is that the mold making material starts to shrink after a period of time. It's said that you can refrigerate and that will preserve it for a time. I'd as soon pour the plug asap so's it's not a concern.
Nov 03, 2020, 09:02 PM
Zipman's Avatar
OOH, that is going to be NICE. Great work Woody. Can't wait to order one from Sparks.
Thank you for doing this. Getting my plans printed tomorrow.
Nov 03, 2020, 09:13 PM
THX Zipman.
Keep us posted on your progress. I'll be interested to see what you'll do with this.
Woody
Nov 03, 2020, 09:45 PM
Zipman's Avatar
Sure will. You got me motivated.
Build Log 1/10th scale North American T-2 Buckeye Ken Lapointe 3D Printed Planes 13 Jun 07, 2020 12:38 PM
Build Log North American T-2 Buckeye Ken Lapointe Scratchbuilt EDFs 76 Aug 28, 2019 09:29 AM
T-2 Buckeye gromitvt10 Fuel Jet Talk 8 Mar 20, 2005 12:03 AM
looking for T-2 buckeye & A-1 Skyraider gromitvt10 Scale Kit/Scratch Built 5 Dec 10, 2002 10:32 AM
