Precision Aerobatics / Het-Rc 20% Extra with Cyclon 160 F3A Motor - RC Groups
May 01, 2005, 06:33 AM
Gaz
Gaz
Gaz's Avatar
Extra 330L 20% ARF Conversion
Designed for 47-90 2s, 80-120 4s ic power
Equipment so far..
Cyclon CY 160 F3A Motor
PolyQuest 8s2p 2600 mah Cells
HackerMaster 77 opto Controller
17 x 8 and 18 x 8 APC e Props
4 x w-150 metal gear servo
JR 770s PCM RX
RX pack 5 x kan 650's
AUW around 3.7 Kg / 8.1lb
May 01, 2005, 08:01 AM
Tragic case
davidleitch's Avatar
Gaz
Tell us a bit more. How did you find the quality of the plane. Presume its a bit early for a flight report? Your grass is too green. Don't they have water restrictions in Cairns?
best
Dave
(in water restricted Sydney)
May 01, 2005, 11:09 AM
The original Flying Pigs Sqd.
Up&Away's Avatar
It's all that Australian beer you guys drink...
May 03, 2005, 04:26 AM
Gaz
Gaz
Gaz's Avatar
Its a good quality ARF kit, I was impressed with the amount of hardware supplied.
This includes all fittings for the closed loop cable system and exit tubes preinstalled. There are also cut-outs for pushrods to the elevator and rudder if you want to use them. CA hinges are provided for the control surfaces. Alloy undercarriage and light weight wheels.
Construction is balsa ply fuse and foam core balsa sheeted wings covered in Ultracote.
Top quality fibreglass cowl and wheel pants.
http://www.precisionaerobatics.com/p...spx?prodID=108
Span 1600mm / 63
Length 1460mm / 57
Ive recently transferred down to Rocky so the colour of the grass in the pics will be changing!
May 03, 2005, 08:32 AM
Forgot how to fly
Mike Parsons's Avatar
Very clean install. I like the motor mount. Custom?
-Mike
May 04, 2005, 05:45 AM
Gaz
Gaz
Gaz's Avatar
Thank's mike, I was lucky enough to have a friend hand machine some motor mounts from a block of alloy for me.
The one shown on the extra is light weight and he also made a radial mount / heat sink I have planed for another higher powered project running the CY 160 more towards it maximum rating.
May 04, 2005, 07:14 AM
Gaz
Gaz
Gaz's Avatar
Underside view of mount and controller..
Peter Pine from www.flyelectric.com supplied the Cyclon CY 160
May 11, 2005, 08:55 PM
Gaz
Gaz
Gaz's Avatar
Here are a few more photo's of the progress
This shows a few of the mods for the conversion.
Normally the bottom wing cover is glued in place, I made his removable by installing locating pins at the front and making a ply bracket for the standard wing bolts. This bracket has 1/4" threads tapped into it for the nylon bolts that secure the back of cover. With the removable wing it is a lot easier to transport and allows access for battery pack.
A small hatch in the cowling was also made for access to the Deans connectors and an exit vent installed for cooling.
May 11, 2005, 09:03 PM
Gaz
Gaz
Gaz's Avatar
There is plenty of room inside for electronics, the rear of the battery pack is just visible in this shot. With the 8s2p Polyquest pack mounted at the front the plane balances right on the 100mm from L/E location. For fine COG adjustments I can move the Kan 650 RX pack.
May 11, 2005, 09:11 PM
Gaz
Gaz
Gaz's Avatar
I've also made the cockpit floors, both are removable, the rear give access to the top of the relocated servo tray for maintenance. The RX pack voltage monitor is located in the front tray.
May 11, 2005, 09:18 PM
Gaz
Gaz
Gaz's Avatar
This is the Polyquest 8s2P 2600 arrangement with 1/8" balsa strips in-between to help cooling. The pack weighs 980 grams. They came from www.aircraft-world.com on special, Bargin!
May 12, 2005, 12:41 AM
Up&Away's Avatar
Wow, that is some battery pack! How do you charge? Do you use the TAPS or the Deans?
May 12, 2005, 12:59 AM
Gaz
Gaz
Gaz's Avatar
Hi Rene, I'm charging via the Deans connector at the moment, 33.6 volts.
I'll use the taps for checking the balance of each cell.
Gary.
Sold HET RC Typhoon Micro 6/20 3D Outrunner with mount punkindrublik Aircraft - Electric - Power Systems (FS/W) 0 Mar 29, 2006 03:52 PM
F/S NIB HET-RC F18 Hornet (Grey Version) With New Wemo 480 Fan unit Lv2Fly Aircraft - Electric - Airplanes (FS/W) 2 Dec 10, 2004 06:55 PM
Speeds for a HET-RC F-18 with Mega motor Longarm Electric Ducted Fan Jet Talk 2 Oct 07, 2004 07:42 PM
FS: Eam (het-rc) F-18 Hornet Arf Grey With Wemotec Fan New Kempf Aircraft - Electric - Airplanes (FS/W) 2 Mar 22, 2004 10:59 PM
Logo 20 Drawings with hot links to RC-Direct's Shopping cart Augusto Electric Heli Talk 1 Jan 24, 2003 01:03 AM
