Youtuber Tom Stanton created a helicopter with a "virtual" swashplate controlled by speeding up and slowing down the main motor. It's explained more below, but this helicopter only has two motors and no complicated mechanical parts. He wanted to create a helicopter that was mechanically simple, but controlled via software similar to how drones are able to fly with multiple motors. Here's the explanation on how it works:
"The main rotor’s motor is equipped with a sensor that lets the controller know its position twice every rotation. By very precisely controlling the motor speed throughout each rotation — from very quick to nearly stopped — Stanton can change the blade pitch angles at the exact point necessary to steer the aircraft. It is amazing to watch and an ingenious implementation of physics, resulting in a surprisingly practical way to fly" - Hackster.io
Be sure to check out the video below, it's a great watch and interesting to see the process used to create this heli.
Drone Helicopter Hybrid (9 min 1 sec) |
Thread Tools |
Hi, a direct drive motor system close to the head is a good idea and has a very cool appearance! But people here like collective pitch systems for 3D flights. In Japan , some inventor, Mr. Nakamura who invented HIROBO XRB and SRB , made a swashplate-less SRB ten years ago:
But he gave up commercialization. I believe Tom Stanton's idea will be appreciated by the company for US military micro drones. |
I would like more info on Mr. Nakamuta system too. If i remember correctly it used a torsion bar in the head to change cyclic?
I think direct drive is a bad idea because it needs a heavy motor. A geared setup can have a much smaller and lighter high rpm motor. This is the reason direct drive did never sell with RC helis. The rotorhead is great, i wish i could buy or construct such a thing for my own experiments. Stanton does measure the rotor position by hall sensor the "analog" way. I think this can be done much simpler. Stanton does the power modulation by sending the ESC multiple values per rotation. He uses a 500hz he says. I bet he didnt remove the ESC input smoothing. I can tell you how on "old" open source esc's ![]() |
Stanton's second vid:
If the battery energy density is the available Horsepower, and the means to an end rotor requires "X" horsepower, I doubt the sum of mechanical weights penalty, "all inclusive" whether geared or direct would be different all that much if designed specific to available HP required.
Latest blog entry: Times up,,......
![]() Those types of motor have linear torque over the whole rpm band. We know "power = rpm x torque", means power rises wit rpm. A small high rpm motor has same power as a big heavy low rpm motor. Thats why rc helis are geared. Same applies to gas motors. Torque figures are nonsense as long as you know how to use a gearbox. Only few people understand this. |
More disturbing is that the individual blade will change pitch with the power applied. This will result in unbalanced rotors during climb or descent. One blade will ride higher than the other -> vibrations. |
True, I didn't think about dynamic braking. My narrow mind was thinking in reverse. Literally. ![]() But assuming you harvest the most of the electrical energy generated during braking (an optimal scenario) I don't see how you would come out ahead compared to traditional designs. I'm not an engineer, but I worked with one once. ![]() https://www.youtube.com/watch?v=8dOHEw8izno |
No camera for you. ![]() It might be something as simple as using ball bearings to support the blade grips, instead of a pin on plastic. It's something new and these folks deserve massive credit for even messing around with it. |
Lost in translation. ![]() |
Thread Tools | |
Similar Threads | |||||
Idea | Fixed wing Hybrid aircraft design | Street racer | Blimps | 7 | Dec 13, 2016 02:40 PM |
Discussion | Why do some 4 CH fixed Pitch Heli's behave differently? | jerrit1 | Beginner Training Area (Heli-Electric) | 48 | Nov 16, 2016 12:37 PM |
Discussion | Convert fixed pitch heli with cc3d brushed | moses123 | Micro Helis | 1 | Oct 25, 2016 11:47 AM |
Discussion | heli max axe 100 fixed fixed pitch heli | lvit2bvr | Mini Helis | 11 | Apr 25, 2014 03:13 AM |
Discussion | hybrid fixed pitch from scratch | stirlingnut | Micro Helis | 36 | Apr 07, 2007 12:24 AM |
