Jul 12, 2020, 08:43 PM
Question
Carbon strip reinforcement
Any suggestions to how I can reinforce a 750mm glider pink foam wing other than the usual carbon 1 x 3 x 750 mm strip. It currently is out of stock. I ordered a cut to order foam wing and forgot this needed that. The usual kit has a scored channel across to fit that. Thanks
Jul 13, 2020, 01:35 AM
If it flies - I want one!
Petem's Avatar
Possibilities might include a strip or strips of fibre tape (unidirectional) top and bottom, pallet strapping, possibly let in a little and glued with UHU Por, cut or sand channels and let in spruce or balsa spars. Or lightweight glass cloth top and bottom applied with thin epoxy or water-based polyurethane?
Pick one and build on!
Cheers,
PeteM
Jul 13, 2020, 02:52 AM
eflightray's Avatar
How about going 'old school' and using a strip of 1mm plywood, or even some hard balsa.
It always worked in the past,
Jul 13, 2020, 12:46 PM
Hi Ray .. just started on this hobby for those rainy days here .. I still need to source a bit of balsa sheets next when I get rather heavily on it. Right now it seems shipping is at least 2wks to a month for most products. Am left with just materials from fixing an f3k type glider and the current balsa/foam mini glider I have. In time I would. Cheers
Jul 14, 2020, 07:08 AM
Retired CAD guy
birdofplay's Avatar
A spool of this stuff will last a life time !
Lighter than carbon , stronger than you need.
https://www.thethreadexchange.com/mi...kevlar_juniors
Jul 14, 2020, 11:30 AM
how do you apply this thread?
Jul 14, 2020, 11:41 AM
Carbon fiber arrow shaft, maybe?
Jul 14, 2020, 12:06 PM
looking online .. would a round shaft be just as strong as a strip to reinforce the wing just like the original?
Jul 14, 2020, 12:13 PM
Retired CAD guy
birdofplay's Avatar
I use Kelvar thread to ...
Wrap the ends of CF tubes to prevent splitting out
Both Wing connection tubes as well as smaller Push rod sized CF tubes
Medium to thick CA secures things after the Kevlar thread soaks and wicks up the CA
just like the Ferrules on Fly Fishing Rods.
Untried but due to thinness of the thread a surface attachment might work well also.
Top or bottom those surfaces
Also Balsa structure Wings can be super reinforced with almost no weight gain.
I have wrapped wings as well as crisscrossed between each Rib bay.
Thin, med, thick CA works good for balsa attachment whatever
Since the thread is so light weight you can get creative with wrapping patterns.
right around the Main spar locatoin is best.
Front view wing section
At under $20 for 300 yds or more you can afford to get creative and experimental
Jul 14, 2020, 12:18 PM
hi BoP .. the carbon strip that comes with the foam wing is around .5mm x 2mm x 300 long and is buried on a scored channel underneath the wing ..
Jul 14, 2020, 03:31 PM
Retired CAD guy
birdofplay's Avatar
Considering that the Foam is one of the softest materials
and that CF is one of the Hardest
I'm counting on Kevlar to strike a reasonable balance at a fraction of the weight.
Jul 14, 2020, 11:54 PM
I've never worked with Kevlar yet am sure just about the same resin and epoxy or CA to go with it.
New Product New Imperial bike speeder Quadcopter reinforced with Carbon fiber Plate UAV.RC Multirotor Drone Talk 1 Jul 17, 2016 08:59 AM
Help! Balsa Table reinforced by carbon fiber? Planery Balsa Builders 9 Sep 21, 2015 12:51 PM
Discussion How do you use carbon fiber strips to reinforce a wing?! Smokescreen38 Parkflyers 15 Feb 23, 2007 02:51 PM
