DLE-130cc Twin Gas Engine with Electric Ignition and Mufflers
This bad boy twin is the DLE-130. It's a 130cc twin gas engine with electric ignition and mufflers included.
Perfect Engine for Your CubCrafters Carbon Cub FX-3
This bad boy twin is the DLE-130. It's a 130cc twin gas engine with electric ignition and mufflers included. It runs smooth and is the perfect engine for the Hangar 9 CubCrafter Carbon Cub FX-3. It's a beauty you can get your hands on for $829.99 at Horizon Hobby and it's in stock right now. Check out the spec list below.
Specifications:
  • Benchmark Prop: 27x12, 28x10, 28x11, or 29x9
  • Bore: 1.85" (47mm)
  • Carb Type: Petal V-type reed valve
  • Cylinders: Twin
  • Displacement: 7.93 cu in (129.94cc)
  • Engine (Only) Weight: 5.59lbs (2,540.1g)
  • HP: 13HP at 8,500RPM
  • Ignition Weight: 0.36lbs (162g))
  • Muffler Weight: Right 0.26lbs (120.4g), Left 0.25lbs (114.9g)
  • Oil Type & Content: High quality 2-cycle, 30:1 mix ratio sold separately
  • Plug Type: DLE-6
  • Prop Range: 27x12, 28x10, 28x11, 29x9
  • Recommended Fuel: 93 octane gasoline
  • Stroke: 1.47" (37.5mm)
  • Total Weight: 6.94lbs (3,152.3g)
Includes:
  • DLE-130 Engine
  • 4.8~12v Electronic (Auto Advancing) Ignition & Spiral Cable Wraps
  • DLE Pump Carburetor and throttle arm extension
  • (2) Mufflers with smoke inlet, Gaskets and Bolts, extensions and clamps
  • Alloy Mounting Plate fixed to engine
  • Machined Aluminium Standoffs ( 4 )
  • (2) Safety clips
  • (2) NGK CM6 Spark plugs
  • 2 Year Factory Warranty
Click here to see the DLE-130cc Twin Gas Engine with Electric Ignition and Mufflers
Jul 10, 2020, 08:07 AM
SCSSNIPER74
Love my 130 so far. Getting More impressed As It breaks in. Idle is nice and seems to tune well.
Discussion New DLE 130cc Twin... PLP Engines 1 Nov 28, 2019 10:09 PM
Help! New to gas, ? test DLE 30 ignition? JBAZ4 Engines 12 Apr 21, 2011 06:19 AM
Help! nitromodels cessna 337 twin gas engine, convert to single electric pusher dr_patso Power Systems 8 Sep 10, 2009 02:34 PM
