iFlight BumbleBee HD V2 CineWhoop BNF
The BumbleBee HD V2 BNF features the amazing DJI digital FPV system which makes flying truly breathtaking.
New Bumblebee V2
The BumbleBee HD V2 BNF features the amazing DJI digital FPV system which makes flying truly breathtaking. With the 720p 120fps video in your Goggles, DJI has set the bar at a new high for clarity and image quality in FPV experience. The whole frame was reduced to a minimum size and weight. We came up with a 145mm diagonal motor distance for our new V2 (V1 142mm) and even fit the DJI Air Unit inside. We've also added a new bumper approach with loads of protective 3D TPU parts to protect yourself and your drone just in case. Small space? Tight gaps? Indoor safety? But you need that 4K? Well, here goes your GoPro! There's always that customer that has this indoor project but just want to get footage in 4K. Here's the BNF you need to get the job done! You have this location you wanna fly in, but no way you'd fly your standard razor blades around you or your friends? Do you just love the style and the fact that "props just won't break that often"? ... GO FOR IT! The V2 sells for $409.99.
Main Change log V2:
  • SD-Card Extension Port (on the tail end)
  • FC type-C Extension Port (on the tail end)
  • LED illuminated Logo
  • Upgraded EVA Protectors, Improved duct profile with less noise
  • Bottom carbon thickness increased from 2mm to 2.5mm
  • The Wheelbase increased from 142mm to 145mm
Features:
  • No Props or frame in view!
  • High performance True-AIO Board SucceX-A (F4 FC + 40A BLHeli32 ESC) to save weight and space
  • T700 Quality Carbon (40% more tensile strength compared to common 3K carbon)
  • Lightweight one-piece frame design (Less flexibility, more Rigid, more Durable)
  • Low Resonance frame construction (Less Jello, more Cinematic footage)
  • DJI FPV Air Unit 720p 120fps FPV feed (record in 1080p/60fps)
  • Butter smooth XING-C 1408 4S 3600KV / 6S 2800KV motors
  • Bumper prop guards to protect sensitive environment or yourself
  • Pre-tuned with smooth freestyle settings
BumbleBee BNF Specs:
  • SucceX-A F4/40A BLHeli32 true AIO board
  • Motor: XING-C1408 4S 3600KV / 6S 2800KV (LINK)
  • Wheelbase: 145mm
  • Body Size: 111*93mm
  • Bottom plate thickness: 2mm
  • Top plate thickness: 2.5mm
  • Top and bottom plate spacing: 27mm (aluminum standoff height)
  • Propeller size: 3 inch
  • FC pattern: 20*20mm,30.5*30.5mm
  • FPV cam spacing: 19mm
  • Weight: 356.7g (without battery)
BumbleBee HD Quad BNF Included Components and Parts:
  • 1x BumbleBee HD V2 Frame
  • 1x DJI FPV Camera
  • 1x DJI FPV Air Unit Module
  • 2x DJI FPV Air Unit Antenna SMA
  • 1x TPU Bracket for DJI Air Unit Module
  • 1x TPU Antenna holder for DJI antenna
  • 2x TPU camera side plate soft mount
  • 2x Nazgul 3040 propeller (Set of 4 - Color May Vary)
  • 2x MMCX to RP-SMA Female Adapter Cable
  • 1x iFlight Lipo Strap
Recommended battery:
  • Fullsend 4S 95C 1300mAh(5-6 minutes flight time w/GoPro Hero8)
  • Fullsend 4S 95C 1550mAh(6-7 minutes flight time w/GoPro Hero8)
  • Fullsend 6S 1300mAh
Check out the iFlight BumbleBee HD V2 CineWhoop BNF Here
Jul 30, 2020, 02:51 AM
nice one thanks
Whoops! iFlight BumbleBee 3 Inch 6S HD CineWhoop w/DJI Caddx Justapoke Micro Multirotor Drones 8 May 23, 2020 02:30 PM
Discussion iFlight Cinewhoop Megabee v2 DJI FPV okayplayer Mini Multirotor Drones 0 Dec 26, 2019 02:29 PM
Discussion GEPRC CineEye 79mm CineWhoop FPV Racing RC Drone PNP/BNF Caddx Turtle V2 1080P HD Merch Micro Multirotor Drones 0 Dec 16, 2019 11:09 AM
